Tractor Talk Discussion Forum
Electric tachometer
37 chief
10-16-2007 21:55:10
How is a electric tach. connected? Thanks stan
Gene Davis (Ga.)
10-17-2007 19:52:35
 Re: Electric tachometer in reply to 37 chief, 10-16-2007 21:55:10
We have an electric tach at work on a sprayer engine that has positive hookup to battery power, negative hookup to ground and there is a small red wire that requires 4 turns wrapped on the spark plug wire and it is very accurate when we check it with other type tachometers. It works like the induction pickup coil on a timing light.
davejoe
10-17-2007 04:03:44
green--neg side of coil
red----power white--dash light black--ground Dave
Jon Hagen
10-16-2007 22:02:33
They normally have one wire connected to ground, one wire connected to switched battery power and one wire connected to the distributor side of the coil primary winding.
Jon Hagen
10-16-2007 22:05:55
 Re: Electric tachometer in reply to Jon Hagen, 10-16-2007 22:02:33
If your talking about a dwell/tach test instrument, they usually only have the wires for ground and dist side of the coil primary.
