Tractor Talk Discussion Forum
99 powerstroke service engine light
Bill in Colo
10-14-2007 12:18:44
will not show on code reader any suggestions
KEB
10-15-2007 07:19:13
 Re: 99 powerstroke service engine light in reply to Bill in Colo, 10-14-2007 12:18:44
What kind of a code reader are you using? The F-350 diesels are only sort of OBD-II compliant, and there are a bunch of codes that a standard OBD-II reader won"t pick up. Some of the programmers (hypertech, ect.) can read the non-standard codes, and the autoingenuity software will read them. If you can"t find someone with one of these, you"re stuck going to a dealer and paying through the nose for five minutes of computer time.
I"ve been looking for a used programmer that"ll read the unique codes (I have a 99), mostly because I"m too cheap to cough up the $400 for the autoingenuity software, but so far haven"t had any luck.
Keith
noncompos
10-14-2007 20:44:12
If you haven't already, make sure the fuel filler cap is going on correctly and snugly; it will turn on the light and sometimes not set a code if it isn't just right. Good luck.
LouNY
10-14-2007 17:03:15
There are several different programs that can go into your computer and read the codes, checkout autoenginuity.com for their software that for a price will do it there are others out there, some for less money (always better)
Good luck
Jim K
10-14-2007 15:30:33
Have you tried disconnecting the batteries for a couple minutes? to see if it clears.
Spook
10-14-2007 15:27:03
 GO TO CHEVY DEALER.... in reply to Bill in Colo, 10-14-2007 12:18:44
Seriously, Methinks somebody isn't usuing the reader correctly.
noncompos
10-15-2007 09:59:20
 Re: GO TO CHEVY DEALER.... in reply to Spook, 10-14-2007 15:27:03
"Go to the Dealer"...well, that depends on the dealer...we had a 91 Cavalier, and the engine started racing (40 MPH with foot off the gas!) Took to good shop, changed various sensors, no help. Shop took to their electronic expert, who had right idea but in middle of mental meltdown, so his work no help. Shop sent us to Chev dealer (shop paying); explained in detail to Chev shop, gave them typed history of problem, work done. They said "talked to factory, fixed now"--wasn't. Only got it fixed by taking to guy who built performance cars, programmed his own computer systems.
Bob
10-14-2007 13:42:14
Sounds like you need to find someone with a better code reader!
ray_woods
10-15-2007 08:03:26
 Re: 99 powerstroke service engine light in reply to Bob, 10-14-2007 13:42:14
Do you have the power stroke module for the code reader? If you do have it, it at least tell you where the code originated from (injectors etc)
