Tractor Talk Discussion Forum
Front tractor tire dilema
ENJ62
10-11-2007 11:48:08
I am restoring a 1954 MH Pony that was used by a town for highway mowing with a sickle bar. I have purchased new R3 diamond patterned rears from Goodyear What would a highway dept normally use as a setup for the front with the R3 rears ? (a tri rib or 5 rib)This tractor will be for occasional use and mostly display. Any input on this?
Thanks Ed
Don-Wi
10-12-2007 01:29:23
 Re: Front tractor tire dilema in reply to ENJ62, 10-11-2007 11:48:08
What size are the rims?
If you can't find anything else that would look right, I would go with a 5 rib implement tire.
A 3 or 4 rib front tractor tire would cut into the grass too much to be matched up with a pair of turf tires on the back...
Donovan from Wisconsin
ENJ62
10-14-2007 17:00:43
 Re: Front tractor tire dilema in reply to Don-Wi, 10-12-2007 01:29:23
Tires are 5.00 x 15
ED
RayP(MI)
10-11-2007 18:01:57
probably 3 rib conventional tractor tires.
JT
10-11-2007 14:25:10
Our Cub Low Boy has the big diamond pattern rears and turf tires on the front. But you may not find turf tires that narrow, though.
M Nut
10-11-2007 11:57:23
Don't know if it is original or not, but my Pony has single rib front tires on it.
