Tractor Talk Discussion Forum
changing ring type hyd. lift piston to o-ring type in a 2N
skip graewert
10-09-2007 17:49:24
Is the o-ring type better and if so where does the gasket for the o ring type go. In the bottom of the cylinder or by o-ring or where?
RickB
10-10-2007 03:03:51
 Re: changing ring type hyd. lift piston to o-ring type in a in reply to skip graewert, 10-09-2007 17:49:24
The backup ring goes away from the oil.
skip graewert
10-10-2007 05:34:06
 Re: changing ring type hyd. lift piston to o-ring type in a in reply to RickB, 10-10-2007 03:03:51
Thanks for the reply. As I understand the O ring goes on first and the backing gasket goes behind the o ring so when you put the piston into the cylinder the gasket is on top towards the push ram.
old art
10-09-2007 19:44:03
by the O ring
