Tractor Talk Discussion Forum
Massey
Olred
10-09-2007 13:42:44
I have a MF-50, and I need the plate that is located on the bottom side of the transmission. Any help ya'll could give me would be greatly appreciated!!
Jeff-oh
10-10-2007 07:19:48
 Re: Massey in reply to Olred, 10-09-2007 13:42:44
If you are talking about the inspection plate you can easily make one out of 1/8" plate. Cut to fit and drill the four bolt holes. Nothign too special about it.
Gerald J.
10-09-2007 20:30:25
Probably the same as many MF tractors. Their MF-236 loader uses the same bolts for the rear mount. On my MF-135 its a flat plate with 4 11/16" holes for the 5/8" bolts and a 3/16" hole in the middle with a 5/32" cotter key through it to let oil spilled from engine or transmission seals drain. Plate probably 1/8" thick.
Gerald J.
marlowe
10-09-2007 15:39:56
are you looking for the inspection plate under the bell housing or the plat that holds the hyd. pump ?
MF Poor
10-09-2007 15:01:49
Maybe some help. That plate will be the same on a Massey 35 or 50. Same tranny/rear end. 35's will be far more common if you're searching bone yards.
