Tractor Talk Discussion Forum
New Cycle bar mower (make unkown)
Walt Davies
10-09-2007 11:42:00
this is the new Cycle Bar Mower i bought for $25 I need to know what make and model it is as I can't find anything on it.
Walt
third party image
third party image
third party image
Walt Davies
10-09-2007 19:34:24
 Re: New Cycle bar mower (make unkown) in reply to Walt Davies, 10-09-2007 11:42:00
Thanks for all the help Fellas I ordered a manual from Binderbooks so it should help me get her up an running in no time. i got a whole bunch of new teeth from the last Owner and some extra rock gaurds too.
I guess I will be able find out what that missing part is although i have a hunch but don't want to dumb so I'm keeping mu big mouth shut for now.
Walt
flying belgian
10-09-2007 18:00:33
Right-o, We mowed for years with one. Damn good mower if you get it set right.
deano
10-09-2007 15:24:05
Yep a 27V, I'm jealous, paid 50 for mine and you have better paint. You are missing the release and the cylinder mounting looks customized. The cylinder you have on it actually mounted in front of the axle on an H or M tractor and had a rod running back to the mower. One hell of a cobble job, gotta wonder what they were drinking for lunch in engineering.
John S-B
10-09-2007 19:52:38
 Re: New Cycle bar mower (make unkown) in reply to deano, 10-09-2007 15:24:05
Nothing wrong with the cylinder the way it is, that was one of the options to lift it. I put a cylinder on mine the same way only mine is a bigger one and the bracket is homemade. Works just great, cut about 30 acres with it.
jeffcat
10-09-2007 15:14:29
Just be CAREFULLLLL when you let that blade down to mow. Count allll of your fingers! Jeffcat
36 coupe
10-09-2007 14:35:40
McCopmick Deering 27V.You are missing the release bar that goes from the knife head to the frame.I still use one.
Steven f/AZ
10-09-2007 12:48:39
I agree with the others that it"s a 27 IH. Many people call them the "A frame" mower. There were probably hundreds if not thousands of those around where I grew up in SW ND. Seem to be a pretty good mower, I know of a couple people that still use them.
Most have switched to haybine, double 9" mowers, or at the very least a pitmanless 9" mower over the last several years.
Wayne from MN
10-09-2007 12:16:02
It is a #27; I ran one for many acres on thehome farm located on the Montana-North Dakota border.
PS: It is spelled "sickle".
I have a manual if you need info.
Walt Davies
10-09-2007 12:26:53
 Re: New Cycle bar mower (make unkown) in reply to Wayne from MN, 10-09-2007 12:16:02
Hey! I was close wasn't I. Walt
PS I found that out looking up parts for it. Giggle
KEH
10-09-2007 11:57:15
It's an IH, not sure of the model number, maybe 27, but I had one like it. Good pitman type mower.
KEH
Walt Davies
10-09-2007 12:04:30
 Re: New Cycle bar mower (make unkown) in reply to KEH, 10-09-2007 11:57:15
thanks I can it up on the Ih parts site.
Walt
