Tractor Talk Discussion Forum
tire chains
Karl Fink
10-07-2007 16:00:59
I HAVE A FORD 2600 WITH TIRE CHAINS THAT KEEP FALLING BETWEEN THE TIRE LUGS AND ARE USELESS. ARE THERE CHAINS AVAILABLE THAT WILL NOT DO THIS OR IS THERE A WAY TO MODIFY MY EXISTING CHAINS SO THAT I CAN GET THE BENEFIT OF HAVING THEM?
135 Fan
10-07-2007 21:04:36
 Re: tire chains in reply to Karl Fink, 10-07-2007 16:00:59
I bought some Duo-grip chains for my tractor that fell in the lugs also. Yes, they are the proper chains. I had a couple bungee cords on to hold them a little tighter but someone on here suggested I take them off. I did and it helped. I also discovered that just by fluke where the cross chains line up when you put them on makes a difference. I noticed the cross chains going in the lugs the most when I was in deep snow and the tires started to spin. I think this is what pulled them in. If the chains are a little looser they usually fall out when the wheel goes around. Duo-grip chains have 2 cross chains close together with 2 short chains connecting them so they aren't supposed to go in the lugs. They still can. I think it's worse on smaller tire sizes. If you just have straight across single cross chains, they wouldn't work very well for an ag tire but would work for an industrial tire like on a grader. Hope this helps. Dave
midwest redneck
10-07-2007 16:51:16
Go to tirechains.com and see what they have on their website.
John51
10-07-2007 16:17:32
Yes, there are other styles that won't do that....sort of a modified X pattern that crosses over the lugs. I bet you can modify yours but it might cost about as much as buying the X type.
