Tractor Talk Discussion Forum
tire question
phil lowe
10-02-2007 19:03:59
Hi guy's ,i've got an oppertunity to pick up a 13.6 28 tire and new rim/tube for a good price,well $400 ,just so happens one of mine is weeping calcuim around the stem,rims getting pretty rusted up ,so, found this "deal"..My Qeustion is this tire is bout half worn ,my tires are bout 3/4 worn,I keep my ice chains on all year round,,so I thought i heard not to run uneven tires,is that true ,should I be going out and getting two with the same wear..Only one used one available.,,
phil lowe
10-03-2007 18:23:46
 Re: tire question in reply to phil lowe, 10-02-2007 19:03:59
I know our Canadian Dollar is par now ,butmost stuff still costs more up here..But thanks,I'll probably try and beat the guy down some on the price ,thanks
marlowe
10-03-2007 18:17:24
that's no deal just put on two new Firestone's 6 ply 23 degree tires were 220.00 each rims were 110.00 each tubes 32.00 each 362.00 total sure ain't no deal
marlowe
10-03-2007 18:21:51
 Re: tire question in reply to marlowe, 10-03-2007 18:17:24
sorry my tires were 12.4-28 but even at that thats still over priced my rims were 11 in. yours might be 12 in. so add 10.00 to the rim
Walt Davies
10-03-2007 09:40:05
Sounds like a high price for that tire I bought 2 used 12.4 by 38 tires mounted at the dealers for $301 both with about 3/4 tread. Walt
RodInNS
10-03-2007 05:49:43
Phil, Don't give it a second thought. Just make sure the wheel you're buying is in better shape than the one you've got. I think you could pick up a new wheel from Nova for about 300 bucks... and I woldn't want to give much more than a hundred for a half worn tire... Might not hurt ya to give Adrian or Sherman a shout down there and see what they want.
I installed an A&I wheel (that size) for a guy this spring and I think it was under 300 for the wheel. I wasn't too impressed with the quality of the wheel since it wasn't rolled quite 'round', but I did finally get it on the center. It's working OK now for him, so that might be something to consider...
Rod
phil lowe
10-03-2007 02:37:56
thanks for the info guy's.
iowa_tire_guy
10-02-2007 19:46:24
I would agree with Jim. There is probably more difference in diameter between brands and by running chains and air pressure than what you are looking at.
Janicholson
10-02-2007 19:22:29
There is no reason to worry. THe difference in rolling diameter will mean absolutely nothing to any wear on the differential. Think of plowing with one wheel gripping well in the furrow, and the other doing most of the slipping on the surface. No one considers that to be a problem, and it is not. On a car, Especially with limited slip differential, and the high speed handling of an interstate to contend with, sure. But tread wear is usually not considered even there. Go for it. JimN
sjh
10-02-2007 19:08:45
Quich solution. Change the old tire to new rim.
