Tractor Talk Discussion Forum
OT: Winter Cover Crop for hay?
Casey in Ky
09-28-2007 09:37:01
Is there anything I can sow this fall that's worth a darn that I can cut for hay in the spring long about April or May? Winter rye? Oats? Any suggestions? Thanks, Casey
Clint Youse MO
09-29-2007 06:30:02
 Re: OT: Winter Cover Crop for hay? in reply to Casey in Ky, 09-28-2007 09:37:01
Lot of guys around me use rye may graze it just a bit in the winter and then let it grow and head to a milk stage to bale for hay after the weather breaks in the spring we have used oats but plant everything in the spring
GeneMO
09-29-2007 05:53:04
Wheat is the obvious choice, but I would ask how are you going to bale and store it? I dont think it stores worth a darn in big bales, outside. If you can put it inside then yes it's good hay.
Gene
RobMD
09-28-2007 19:52:08
I used to do rye. It's pretty fun to cut.
gene bender
09-28-2007 18:30:21
Please just go to your local extension office as they will know which seeds are correct for your area and your needs.
Tradititonal Farmer
09-28-2007 18:54:45
 Re: OT: Winter Cover Crop for hay? in reply to gene bender, 09-28-2007 18:30:21
Apparently you have never had any real life experience with gov't bureaucrats
dobber
09-28-2007 12:49:50
Many triticale varieties will get tall and make better and more hay or silage than wheat. Or a grazing blend of grass, oats, wheat, triticale & rye for just grazing.
Tradititonal Farmer
09-28-2007 10:39:51
Winter Oats and Hairy Vetch planted together
Mike (WA)
09-28-2007 11:26:05
 Re: OT: Winter Cover Crop for hay? in reply to Tradititonal Farmer, 09-28-2007 10:39:51
They would make a great silage crop, but at least in my country, if fall planted, they're ready to cut for hay long before the weather has turned.
Jimmy King
09-28-2007 10:23:45
Cut at the right time, no better hay than Wheat.
mjbrown
09-28-2007 17:40:16
 Re: OT: Winter Cover Crop for hay? in reply to Jimmy King, 09-28-2007 10:23:45
What's the right time? before it heads out?
mjbrown
09-28-2007 10:21:24
I've heard of oat hay but usually I think sown in spring and baled in summer.
