Tractor Talk Discussion Forum
Cat 212 Grader----can another engine be installed??
Leaky Boot
09-28-2007 06:38:46
Something like a gas combine engine be made to work without a major problem???
super99
09-29-2007 02:54:21
 Re: Cat 212 Grader----can another engine be installed?? in reply to Leaky Boot, 09-28-2007 06:38:46
If it's just the Pony motor thats bad, I have heard of guys putting a lawn mower engine on in place of pony. I think Farm Show mag had a piece about changing old Cat's over to electric start. Might want to check that out. If you do switch engines, I would go with diesel instead of gas. Chris
markct
09-28-2007 16:45:03
 any engine will fit in reply to Leaky Boot, 09-28-2007 06:38:46
just depends how much adapters and such ya wanna make, my cat #9 grader has a 300 six from a early 80s ford pickup, definatly not a bolt in job, had to make a whole subframe for the motor and stuff
335LP
09-28-2007 12:55:05
Why not a diesel combine engine? Gallion graders used IHC gas or diesels.
Walt Davies
09-28-2007 10:28:37
WHY?????
Walt
Leaky Boot
09-28-2007 12:31:09
 Re: Cat 212 Grader----can another engine be installed?? in reply to Walt Davies, 09-28-2007 10:28:37
Why? Maybe because the current pony start engine has a problem as well as the pony has a problem. ???
Walt Davies
09-28-2007 13:53:00
 Re: Cat 212 Grader----can another engine be installed?? in reply to Leaky Boot, 09-28-2007 12:31:09
Be a lot cheaper and easier to fix it rather than adapting another engine to it. Also those old pony starts are neat.
Walt
buickanddeere
09-28-2007 06:54:13
Anything is possible with enough time and money. Either the bellhousings have to match or use an adapter plate. 53 and 71 series Detroit Diesels are cheap and reliable.
Brokenwrench
09-28-2007 09:50:38
 Re: Cat 212 Grader----can another engine be installed?? in reply to buickanddeere, 09-28-2007 06:54:13
And Loud :)
Dave in Tx
09-28-2007 13:07:11
 Re: Cat 212 Grader----can another engine be installed?? in reply to Brokenwrench, 09-28-2007 09:50:38
and leak oil..... ..
