Tractor Talk Discussion Forum
Allis CA Slow Hydraulics
Al Cockrell
09-27-2007 05:12:52
My '53 CA runs great, the hydraulics work, but are really, really slow picking up my disk. It seems to improve a bit as it gets warmed up, but still too slow to suit me. I've had the pump apart, all seems fine, I've got the adjustment at the front of the pump all the way out, and it's still slow.
old
09-27-2007 07:36:06
 Re: Allis CA Slow Hydraulics in reply to Al Cockrell, 09-27-2007 05:12:52
What type and weight of oil are you using in it?? If your using the 80W-90 switch to hy-tran and the speed will improve a whole lot.
Al Cockrell
09-27-2007 12:04:19
 Re: Allis CA Slow Hydraulics in reply to old, 09-27-2007 07:36:06
I can't even remember what's in it now, I've ran a few gallons through it, it had a little water in it, I pulled the pump, etc..re-packed the lift arms. What weight is the hy-tran?
old
09-27-2007 13:00:35
 Re: Allis CA Slow Hydraulics in reply to Al Cockrell, 09-27-2007 12:04:19
Not sure what the weight of it is but its made to be used in both trannys and hyd systems so it works well in the CA, B and C Allis tractors. I use it in my Cs
