Tractor Talk Discussion Forum
Gulf Tractor????
slinville
09-25-2007 08:16:51
I have located a tractor. On the front of it it reads GULF. I am assuming that is the company? Is it foreign made? Can't find any information ANYWHERE can anyone help me????
slinville
10-09-2007 08:36:28
 Re: Gulf Tractor???? in reply to slinville, 09-25-2007 08:16:51
I have more info on the tractor. I HAVE STARTED A NEW POST. Any info is welcome. Thanks
slinville
10-01-2007 08:22:53
I won't be able to get pics until next week. I will get them on as soon as possible. Sorry
noncompos
09-26-2007 10:26:58
Curiouser and curiouser... Slin: when you have an opportunity to see it again, get a bunch of pix (you never know when someone'll decide to scrap something old). While I wouldn't be able to tell a Terex from a Farmall, most here could make very experienced guesses as to its mfr or parents/relatives if they could see it.
ALSO: will someone who has a copy of Wendels book-the one with the 900 or so names-advise if anything "Gulf" is listed?? This could be a prototype (or something someone stuck a "Gulf" radiator on from something else, although what little I have on Ind/Const/Stationary eqpmt doesn't list any "Gulf").
ALSO: Does anyone here have any family members or contacts who worked for Gulf Oil Co?? While it's certainly far fetched, it's possible the Oil Co might've had some eqpmt "badged" as an advertising gimmick.
slinville
09-27-2007 05:09:11
 Re: Gulf Tractor???? in reply to noncompos, 09-26-2007 10:26:58
I am hoping to get some pics this weekend. I will get them on here as soon as I can.
RobMD
09-25-2007 17:44:41
maybe you're looking at the gulf gas station trucks
WalJohn
09-25-2007 15:11:54
City of Corpus Christi Bid Awards website has a Gulf Tractor Company listed under Tractors and Mowers for $84,400.00.
http://www.cctexas.com/purchasing/admin/webrpt_bidawards.cfm[url][/url]
Kent in KC
09-25-2007 12:48:56
How about a picture of this mystery woman.
slinville
09-25-2007 10:59:33
The GULF is cast into the top of the radiator in red. The tractor is yellow, old, sitting between two trees. It has Ag tires. It also has a wooden belt pulley. I'm pretty sure it was a 4 cylinder. It runs off of gas. Its not handy to go look at so I am trying to remember everything about it.
noncompos
09-25-2007 21:45:04
 Re: Gulf Tractor???? in reply to slinville, 09-25-2007 10:59:33
Slin, you might've found something unusual...by "cast into the radiator" I assume it's a cast iron radiator shell, which usually means old, as you say, and a wooden belt pulley I would assume also means old. D'you remember what the sides of the engine looked like: more or less smooth one-piece block (relatively modern), block with rounded areas on upper sides of block for cylinders (older) or maybe the upper part of the engine looking like two or three separate parts, bolted to the bottom part of the block? (old engines sometimes cast cylinders "in pairs"; a 4cyl would have two "pairs" (upper part of engine) a 6cyl would have three "pairs", and even older engines sometimes had individual separate cylinders). It's beginning to sound fascinating!
PS: Google shows a Gulf Tractor Company, a JD and Kubota dealer in Corpus Christi; where's this tractor located?(not precisely, just a rough area of a state).
slinville
09-26-2007 09:03:45
 Re: Gulf Tractor???? in reply to noncompos, 09-25-2007 21:45:04
I honestly can't remember exactly what the engine looks like. I will have to go look at it again. It is in Kansas.
I am wanting to say it had spoked wheels. Not one hundred percent sure though.
noncompos
09-25-2007 09:56:30
Well, everyone loves a mystery....but a little more desc might be helpful, like f"rinstance: old? newer? new? tires? tracks? size? eqpmt (ag/ind)? looks similar to a? gas/diesel? running/parked/upside down at bottom of canyon/in boneyard?...stuff like that.
It"s a little awkward, looking for something, when you have no real idea of what you"re looking for...(I do hope the "Gulf" isn"t painted on and the "Oil Co" weathered off) "Gulf" cast in radiator? attached nameplate/medallion?...questions, questions...
RAB
09-25-2007 11:03:49
 Re: Gulf Tractor???? in reply to noncompos, 09-25-2007 09:56:30
Now then, noncompos,
Don't be so hard!! Prolly just got the spelling wrong. Maybe it's a GOLF tractor. After all, it had a DRIVER, could be a LONG iron (straight 6), and perhaps it goes PUT, PUT or PUTTER. It might be coloured red or perhaps a GREEN colour. Sounds more like a John Deere two cylinder all the time:).
Now, is it a FAIR WAY from this guy. Watch out for a HOLE in the block... Sorry running out of puns.... leave it for someone else to add a few.....
Regards, RAB
JTinNJ
09-25-2007 15:27:30
 Re: Gulf Tractor???? in reply to RAB, 09-25-2007 11:03:49
Would it be buryed in the sand?
