Tractor Talk Discussion Forum
PHOTO - 3 in front 4 behind
David in Wales
09-25-2007 02:03:22
third party image
Its hard to get both units set up to produce even work but this Overum demonstrator is doing a good job. Front 3 point hitch is becoming very popular here to utilise the full power available, mainly front mounted cultivators are used, and some add extra weights to counter-balance heavy rear implements.
David
MF#1
09-25-2007 06:10:42
 Re: PHOTO - 3 in front 4 behind in reply to David in Wales, 09-25-2007 02:03:22
Excellent picture! It would be my luck to hit one of many ledges with the front one and bend it like a pretzal! Like you said, hard to get set up and probably hard to turn around;-)
IaGary
09-25-2007 04:47:23
There may not be an answer for this but wouldn't it be easier to buy (cheaper), hookup, set, and run one 7 bottom plow on the back?
Just wondering (:~}) Gary
jhill52
09-25-2007 06:08:26
 Re: PHOTO - 3 in front 4 behind in reply to IaGary, 09-25-2007 04:47:23
The idea is to use a smaller tractor to do more work. A couple years ago at MSU I saw an 80 or 90 hp tractor with a 4 bottom in front and a 4 bottomn in back.
Allan In NE
09-25-2007 04:36:49
Aw,
There's the rest of it. :>)
Allan
El Toro
09-25-2007 03:55:33
third party image
Sure is a nice setup and picture. Would like to hooked that tractor to this vehicle for drawbar pull test. Hal
Rich Va
09-25-2007 03:16:27
Over here they just hook all the plows behind the tractor.
mjbrown
09-25-2007 05:48:28
 Re: PHOTO - 3 in front 4 behind in reply to Rich Va, 09-25-2007 03:16:27
Over here we just don't plow much anymore. Uses too much fuel.
Tx Jim
09-25-2007 02:04:41
 Re: PHOTO - 3 in front 4 behind in reply to msb, 09-25-2007 02:03:22
Looks like this rig would be really a challenge transporting down a country road. Great pic's. Tx Jim
