Tractor Talk Discussion Forum
tires/cactus
n8terry
09-23-2007 21:35:28
I purchased a new lawn tractor which I will use over some native grass land. This ground has some cactus on it which may puncture my tires.
Anyone have suggestions on what I should put into the tires to solve the problem? Should I do it before the puncture or after.
Johnski
09-24-2007 16:28:48
 Re: tires/cactus in reply to n8terry, 09-23-2007 21:35:28
I"m a mechanic for our town"s highway dept.(which also includes the park and grounds dept.) I have a large assortment of tractors,mowers etc. I use a sealer called Amer-seal that I buy by the case from my local NAPA jobber. The advantage of this sealer over the green slime is that it can be washed out of a tire with just hot water. This is important when you get a larger punture that must be patched from the inside. HTH Jf
iowa_tire_guy
09-24-2007 04:08:45
Use a sealer. Just not the inflating kind, in those the sealer is too thin and quits working in a few months. The thick kind like slime and others should work good. We buy it by the 5 gallon bucket to use on tires that are in thorns much tougher than cactus.
Walt Davies
09-23-2007 23:10:22
I used to get all kinds of flat tires on my lawn tractor then sears put that sealer in then with a lifetime warranty against flats so far in 4 years they replaced one front tire which I thought was good but they didn't. Hey no more flats is great.
Wish i could say the same thing on my other stuff. I have a flat on the rear of the Case 485 and one on the Brush Hog right now and a hole in the radiator Dad Day at Black Rock. Walt
Leland
09-23-2007 22:34:05
fill the tires with foam they will be solid and then cactus thorns will never be a problem
TomTex
09-24-2007 02:32:20
 Re: tires/cactus in reply to Leland, 09-23-2007 22:34:05
Better to just add the slime stuff. Foam will be so hard that the mower will beat itself to death, as well as the operator. Tom
