Tractor Talk Discussion Forum
Manifold Nuts, Stainless Steel Or Brass?
SuckRusty
09-23-2007 17:39:05
I've tried locally to find the brass but have not been successful. Stainless nuts are available but I don't know if they are as good as the brass. Would stainless work as well as brass when time comes to remove manifolds or should I continue searching for brass?
glennster
09-24-2007 05:57:51
 Re: Manifold Nuts, Stainless Steel Or Brass? in reply to SuckRusty, 09-23-2007 17:39:05
napa usually has brass manifold nuts, if not they can order them. fastenal can also get them for you.
Walt Davies
09-23-2007 22:59:22
just Google Brass Nut and you will find dozens of places online where you can what you want.
If it had brass as original then i would go with that as they look real good.
Walt
CraiginMO
09-23-2007 21:26:54
SS threads stretche when over torqued. I have had many sieze on me. use reagular old steel and don"t worry about it.
RAB
09-23-2007 23:00:55
 Re: Manifold Nuts, Stainless Steel Or Brass? in reply to CraiginMO, 09-23-2007 21:26:54
SuckRusty,
Didn't you learn not to over-torque them?
Rest of list,
Brass hexagon, a drill, a tap and a cut-off tool. In the lathe it is short work to knock out what you need and you can make them deeper if you prefer.
Regards, RAB
NC Wayne
09-23-2007 20:25:31
I"ve never had any problems using brass nuts and have done it many times over the years. As another post said the stainless ones do have a tendency to sieze after awhile. As for using a nickle based never sieze, it"s a good idea, and it will help the nut will come off easily for awhile regardless of what material it"s made of. Still, regardless of the claims that it handles the high heat, in the long run it"s all pretty much worthless. McMaster Carr should have them but if you can"t find the brass nuts then go with a grade 5 plain or coated steel. When it comes time to take them off the steel nut will be alot softer, therefore easier to split, than the stainless one will. In fact when removing a nut on an exhaust system the best way to get it off, with little effort, is to split or at least spread it with a sharp cold chisel. A couple of good hits with a chisel, in a verticle direction, on one of the flats either spreads or splits the nut enough that 98% of the time it"ll come off easy.
RobMD
09-23-2007 19:50:37
A regular steel nut on a stud is much less troublesome than either brass or stainless on a steel stud... when it comes to heat.
37 chief
09-23-2007 19:32:50
From my experience with stainless steel it is good until it gets some heat, and it will gall and you will end up with a real mess. It will gall sometimes even without heat. I was around a lot of stainless in my last job, before I retired. I would just use good grade nuts, and some antiseeze. Brass seams not to be much better. Just my opinion. Stan
Bus Driver
09-23-2007 17:55:47
I know that I will catch some flack about this, but steel and brass together causes the steel to deteriorate faster than steel-on-steel. The brass nut might come off easier later because it is far weaker than steel and will yield easier. The stainless steel is the better choice. Nickel-based antiseize compound on the studs is a good idea with any type studs and nuts.
Bob
09-24-2007 07:31:25
 Re: Manifold Nuts, Stainless Steel Or Brass? in reply to Bus Driver, 09-23-2007 17:55:47
I agree with you 100%, Bus. Stainless steel nuts and anti-seize will work GREAT.
