Tractor Talk Discussion Forum
Magneto help
teacher on the
09-23-2007 16:42:54
I need an expert!!! I was mowing with my farmall B and it just stopped. Gas was ok but could not get a spark. Cleaned and set points and still not spark. I took the Bosch magneto apart and all looks fine. How do I test the coil to see if its good. I checked the resistance to the iron core and bot the spark lead and the one to the points show O ohms. To me this sounds like a dead short inside. Any help on how to test the coil would be appreciated.
Thanks
greenmech
09-23-2007 19:12:25
 Re: Magneto help in reply to teacher on the side, 09-23-2007 16:42:54
Not an expert. You would get a reading if the ground wire was attached to the core.The coil can be tested by going between the spark lead and the points lead and ground lead. If your coil tests to ground with out the wire hooked up the coil is shorted. An open in the coil will be no reading between any of the terminals. Have you tried a new condenser? Ron Mn.
Mo teacher
09-24-2007 10:17:49
 Re: Magneto help in reply to greenmech, 09-23-2007 19:12:25
Not yet. but rand a test and it seemed to work but may not know what I'm doing.
