Tractor Talk Discussion Forum
cutting a truck in half
big N
09-22-2007 19:19:46
I was wondering how to disasemble or cut apart the bed of a truck from the front with mimamal tools
Leland
09-23-2007 03:09:40
 Re: cutting a truck in half in reply to big N, 09-22-2007 19:19:46
There is usually no more than 6 bolts holding the bed on just cut or grind the nuts off and wa la it's off .
Janicholson
09-22-2007 20:43:20
If you want to make a trailer, the easy way is to cut the frame (a good Sawsall with a Lenox brand 12 TPI metal cutting blade is best) Cut as far forward as possible, way under the cab so the two frames stick out as far as possible to form the triangle of the tongue of the trailer. Be sure to block things up very well, and remove the fuel tank before starting to avoid fires. I would replace the rear axle with a tube axle from a trailer store rather than keeping the truck banjo (which weighs too much in a trailer and makes them handle less well and pull harder. Be safe and take your time. JimN
Lanse
09-23-2007 06:43:01
 Re: cutting a truck in half in reply to Janicholson, 09-22-2007 20:43:20
Gee, I thought I knew it all!!! :)
Joe(TX)
09-23-2007 10:40:50
 Re: cutting a truck in half in reply to Lanse, 09-23-2007 06:43:01
Apparently you don't know how not to be a smart mouth. grow up.
poogie
09-23-2007 13:35:02
 Re: cutting a truck in half in reply to Joe(TX), 09-23-2007 10:40:50
I see nothing smart mouthed about his response. He is a better man at 14 than you appear to be
Joe(TX)
09-24-2007 05:29:44
 Re: cutting a truck in half in reply to poogie, 09-23-2007 13:35:02
Give me a break. Too many idiots here.
John S-B
09-22-2007 19:35:29
If it"s not too rusted, just loosen the bolts holding it on, An electric or air impact will work for that. If you don"t have that a sawzall is also a very good tool for that.
RobMD
09-22-2007 19:38:12
 Re: cutting a truck in half in reply to John S-B, 09-22-2007 19:35:29
You can't really get those tools in between the framerails.
I'm fond of grinding/burning the carriage bolt heads off in the bed (if they're terribly rusted), then it'll just lift right off.
John S-B
09-23-2007 20:36:32
 Re: cutting a truck in half in reply to RobMD, 09-22-2007 19:38:12
Depends on what kind of truck, I was able to take my bed off my Dodge to replace the fuel fill tube with a ratchet from underneath.
