Tractor Talk Discussion Forum
firing order
Kent Teller
09-20-2007 13:02:46
I know its stupid but its been awhile and I need to be sure. WD firing order is 1243. no. 1 is flywheel end or pulley end?
melharlan
09-20-2007 19:38:34
 Re: firing order in reply to Kent Teller, 09-20-2007 13:02:46
Had a '56 jag XK140M. They counted from the flywheel end as no.1 Firing order was 624153 Brits had to be a little different! Wrist pin was a gudgen (sp) pin, spark plug was spark coil, top was bonnet.
JMS/.MN
09-20-2007 18:01:52
Might be others, but the only one I've heard of that starts at the rear is a Deutz engine. Otherwise, No. 1 is at the front.
Jerry Coulter
09-20-2007 17:17:51
No 1 is at the front, closest to the radiator.
RAB
09-20-2007 13:54:19
These old engines generally conformed to system of #1 at timing end, all dot punch marks or other markings on rods, caps etc. on timing side.
Regards, RAB
Dick L
09-20-2007 13:05:57
1243 is correct.
