Tractor Talk Discussion Forum
a wrench in the plan...
Don-Wi
09-20-2007 00:34:02
We were supposed to get the bagger either late Tues, or Wed. Morning.
Now the other guy who rented it still has it and we won't see it until probably noon Thurs, and my dad and i both took time off from work to get it done.
We picked up the 986 from the shop down the road (sadly, they only put 6-7 hours on it over the last 2 years since we used it last). While eating lunch dad and I decided we should get something done instead of sitting on our hands, so I hooked onto the haybine and dropped about about 35 acres of 4th crop and 5 of new seeding that was oats and was combined back in June/July. We plan on putting that in the silo on top of maybe 2 loads of corn.
Basically, we've got 4 days to chop about 20 acres of corn and 40 acres of hay, switch the heads over atleast once, (twice if the bagger doesn't come soon enough) and with any luck watch my brother run the marathon on Sunday and sit down for the big family meal on Saturday.
Did I mention that rain that wasn't supposed to be here until Friday night (and not when we'd be running) is now forecasted for about noon?
Doesn't look like I'll have time for church on Sunday at this rate...
Donovan from Wisconsin
rrlund
09-20-2007 16:26:51
 Re: a wrench in the plan... in reply to Don-Wi, 09-20-2007 00:34:02
You've gotta know Don,one of those days after you get the bagger is going to go like today did for me. Luckily I didn't set too high of a goal,just wanted to chop the last 5 loads of corn where I was chopping and get things moved to the next field.Figured anything else was gravy. I thought I had enough fuel to finish when I quit last nite,but the first load I could see that wasn't gonna happen. So,I took the load home behind the tractor and chopper,filled up,relaoded the grease gun that had run out before i was done using it,unloaded and went back. I got half way across the field and blew a steel hydraulic line on the chopper. The header was down against the stop,so I kept going. Halfway back up the other side,a chain broke that's about impossible to get to with the header down. I did get done and get to the next field like I wanted too,but I'd have sure been disapointed if I'd been up against the clock on anything.
Don-Wi
09-20-2007 19:29:54
 Re: a wrench in the plan... in reply to rrlund, 09-20-2007 16:26:51
I hear ya there... We chopped 2 loads befroe noon and before the bagger got here, and then I took the head of and was gonna put the hay head on after welding a little bit on it.
While dad and I were eating our lunch he called and said he was on his way and would be here by 2:30, so we figured we better just put the corn head back on. I still got the hay head fixed so it's ready to go, and we cleaned up the area where the bag was gonna go while waiting. They go here a little closer to 3, set up and started unloading right away. Still got 9 loads chopped, and 6 in the bag so far.
pjbrown
09-20-2007 06:06:38
pile it on the ground and pack it. Plus it will be quicker if you have a dump truck or 2. direct chop into the truck..... works great we do it all the time.
RickL
09-20-2007 03:36:07
So pile it on the ground pack daylights out of it and tarp,done it for years that way. Did the bag once to high priced and the varmints love to chew them up anyway.thought you said your dad was unemployed. plan on cutting 4th and fifth cut next week. got finished auger assembly yet this week have done close to 40 some this season.
Don-Wi
09-20-2007 22:34:43
 Re: a wrench in the plan... in reply to RickL, 09-20-2007 03:36:07
We did a bag 2 years ago and it worked out great for us. The neighbors mostly use either bunkers or pack it in piles like that, but the amount of waste they get is unreal. Some tarp and cover, others don't, so it's not just that they don't cover it or that they don't pack it tight.
With the bag there was NO waste. Period. Just for that it's gotta be worth something.
We haven't had any troubles with mice chewing on bags (or other varmints) so we're not really concerned. We went with a 150' bag as opposed to a 200' bag which costs about another $200-250. If it doesn't all fit, we'll put that in the silo. If it does fit and we have some room, we may just try putting a little hay in it and see how that works out.
Dad has a temporary job with my brother right now so he did just tell him he can't work the rest of the week. We got the bagger about 1 1/2 days late but we've already got 6 loads in it and 3 more on the wagons so dad can get started while I'm waking up.
The corn is pileing up pretty quick so far. For the most part it's all above or very close to the top of the ROPs/canopy on our chopper tractor, an Oliver 1855.
