Tractor Talk Discussion Forum
Cub Cadet Kohler 12 HP compression
Matthew Berg
09-18-2007 18:05:04
I have a Cub Cadet 123 with a 12 hp Kohler cast iron motor. ANybody know what the compression should be? I am reading 40 psi wet or dry.
Thanks!
ktheo1
09-19-2007 18:38:45
 Re: Cub Cadet Kohler 12 HP compression in reply to Matthew Berg, 09-18-2007 18:05:04
If I remember right the compression release is activated when the throttle is all the way back in idle position on 12Hp cadets . Shove the throttle up and see what reading you get.
Bob
09-19-2007 06:53:50
 Factory Manual in reply to Matthew Berg, 09-18-2007 18:05:04
Take a look at Page 23 of the factory manual at the link below: (.pdf format)
willie in mn
09-19-2007 03:45:31
Mathew,
Have 10 horse Kohler in my JD, shop book says operating range 110-120# comp, rebuild if below 90#.
Started burning excess oil & power loss this summer. Best comp test showed 50#, so pulled engine this week. If can get another 36 years service I'll be satisfied.
Wayne in MN
09-18-2007 18:25:13
To get a decent compression test you have to rotate the engine backwards so the compression release is not lifting the exhaust valve and releasing some compression during cranking.
Buy a cylinder leak-down tester; it is much more useful than a compression tester especially on small engines. I have used one for years with great results.
