Tractor Talk Discussion Forum
PHOTO - walk behind rotovator
David in Wales
09-18-2007 10:21:33
third party image
Hired this Italian built BCS rotovator to work the soil down on the area to be re-turfed. 8HP gas Honda engine, 1F & 1R gears. The forward gear is slow for rotovating. You can turn the handle bars around 180 degrees to make a push power unit and fit a sicklebar mower attachment - the reverse gear is used for pushing and is faster speed.
David
Fawteen
09-18-2007 10:26:42
 Re: PHOTO - walk behind rotovator in reply to David in Wales, 09-18-2007 10:21:33
We had a half dozen of those when I worked at the equipment rental place. 3 were rigged as rotovators (or tillers as us Yanks call them) two were set up as sweepers, and one was set up as a snowblower.
Lots and lots of clutch and transmission problems with them, and the handlebar mounting system was aa weak point, but those Honda engines are bulletproof.
