Tractor Talk Discussion Forum
OT: '91 Buick window
CWL
09-17-2007 05:20:48
I'm hoping one of you fine folks has been through this once already. I'm working on a '91 Buick Le Sabre back door window. The window is still on the track, but the power up and down is not working right. The window moves up and down loose and will not roll up with the motor. I took the panel off of the door for a look and there are cables that make it go up and down. The motor runs the cables but they are loose and not working the window. I'm guessing that one of the cables has jumped out of place or slipped. Anyone messed with one of these before?
CWL
09-17-2007 07:20:38
 Re: OT: '91 Buick window in reply to CWL, 09-17-2007 05:20:48
Sorry I ment 2001
Mike M
09-17-2007 06:57:10
I just looked it up. No cables on that model. It uses the plastic tape. This is good news as you should be able to fix it pretty cheap with just a new tape. GM has discontinued that whole regulator by the way and I think the tape too. A local dealer may have some left around or the aftermarket may too.
And yes the 2000 and up models have alot of trouble with their cable setup.
bradk
09-17-2007 05:38:09
Cables? The factory GM C and H bodies in that year had an arm system in a scissor fashion with horizontal guides and the motor ran against teeth on one scissor arm.No cables
CWL
09-17-2007 05:54:13
 Re: OT: '91 Buick window in reply to bradk, 09-17-2007 05:38:09
No it is definately a cable system. It is a very small steel cable. One side of the cable has a housing around it and the other is bare. Something has come loose because the cable has a lot of slack in it, but it still moves when the motor is activated in each direction. I did a quick google search. Seems that this is a very common problem, but only on the 2000-2005 Le Sabre. There are a lot of people griping about it, but nothing as to how it might be fixed other than replacing the assembly. Seems like prices range from around fifty dollars to many hundreds of dollars.
bradk
09-17-2007 05:58:46
 Re: OT: '91 Buick window in reply to CWL, 09-17-2007 05:54:13
Sounds like aftermarket power windows.
Allan In NE
09-17-2007 05:42:30
Think he is talking about one of those plastic/nylon "chain" outfits that had the habit of stripping a tooth out of the chain.
Been too many years ago for me to remember tho,
Allan
glennster
09-17-2007 06:05:35
 Re: OT: '91 Buick window in reply to Allan In NE, 09-17-2007 05:42:30
if its just the nylon ribbon, you can get a universal replacement from napa. hey dont fit bad and are a lot cheaper than buying the regulator assembly from the dealer.
bradk
09-17-2007 05:56:09
OH- Those dang things.I used to have a roll of that stuff around when those cars were king.~brad
Allan In NE
09-17-2007 05:26:54
If I remember right, you have to replace that whole regulator.
Allan
CWL
09-17-2007 05:55:12
 Re: OT: '91 Buick window in reply to Allan In NE, 09-17-2007 05:26:54
I'm afraid that I might at that!
