Tractor Talk Discussion Forum
near-fatal tractor accident
hillbillyOH
09-16-2007 05:56:12
MADISON TWP., Butler County � James Cockerham credits his survival to God and a pocket knife.
The 83-year-old Madison Twp. man, pinned underneath a tractor for four hours Monday, dug out with a knife he keeps in his pocket.
Cockerham was trying to remove a post from the back of his 4-acre yard when the tractor flipped 180 degrees, landing on top of him.
"I was laying right under that seat and that seat had me right here," he said Tuesday, indicating a spot right below his rib cage. "I said, 'Lord don't let me die under this tractor.' If I had been a big man with a big chest, that seat would have crushed me to death."
Before he could dig, he had to labor for more than an hour to free his right leg, trapped above a wheel axle.
Cockerham spent the next two-and-a-half hours digging � an idea that came to him after remembering how trapped raccoons would try to dig themselves free.
Once free, he put on his clothes, which he'd removed to aid his escape. He walked about 150 yards to his home, called his daughter, then 911. He suffered arm bruises and cuts to his chest and back.
This happened right up the road from me. The tractor was an 8N, and the old man was using it to pull wooden posts when it flipped.
Spritzer
09-17-2007 07:46:21
 Re: near-fatal tractor accident in reply to hillbillyOH, 09-16-2007 05:56:12
Question: Why does the stump need to be pulled out of the ground? Why not just saw it off flush with the ground?
Kent in KC
09-16-2007 19:48:42
Pull backwards, facing the task, it can't flip you over. Watch what you attach the chain to, lest ye rip off thine front axle. And be gentle with ole Betsy or she'll find another way to bite you.
Blue3992 (N Illinois)
09-16-2007 09:31:50
Dang. I still consider myself a novice when these old tractors are concerned, but I have picked up two general rules from these boards:
1. Don't get sideways on a hill your tractor can't handle.
2. Don't hook a tractor to a fixed object (tree stump, fence post, etc).
Sounds like this guy violated rule #2.
rrlund
09-16-2007 08:07:45
My son in laws Dad put an 8N on top of himself using a brush hog. The dealer told him not to use it without an overriding clutch on the PTO. He thought the guy was just trying to sell him something he didn't need. He was turning too close to a stump,pushed the clutch in and it kept right on going right up over the stump and over on top of him. Just a few scrapes and bruises luckily.
bill mar
09-16-2007 07:17:58
any thoughts on how he had the post hooked up to cause a tractor to flip like that?
Gerald J.
09-16-2007 07:45:30
 Re: near-fatal tractor accident in reply to bill mar, 09-16-2007 07:17:58
Hitched high, maybe to the top link or at least the axle. Or with the three point raised.
Such stump pulling is often fatal because of the tractor climbing the ring gear. I saw a similar thing happen with a wheeled scraper behind a Ford, probably bigger than an 8N. The front frame crossmember of the scraper passed between the seat and the steering wheel. Left no place for the operator to survive.
Gerald J.
suptscottyb
09-16-2007 08:01:14
 Re: near-fatal tractor accident in reply to Gerald J., 09-16-2007 07:45:30
Gerald, could you explain that alittle more? Also, my guess would be that he had nothing in the 3pt...lucky man, still.
Gerald J.
09-16-2007 11:56:19
 Re: near-fatal tractor accident in reply to suptscottyb, 09-16-2007 08:01:14
How high you hitch the stump controls how easy it is to tip the tractor back.
If you keep the hitch low, the pull of the stump pulls down on the front opposing the rise from the torque of the back tires. Figuratively when the back tires can't move, the tractor climbs the ring gear in the differential with the pinion gear. That is resisted by the weight of the front of the tractor on its moment arm.
When you hitch high, like axle high, then the pull of the stump doesn't hold the front of the tractor down. When you hitch above the rear axle, the pull of the stump helps the front of the tractor rise.
When you use the three point there is nothing to hold it down on most tractors so if you hitch to a post up high it raises the three point and moves up the hitch point giving the same effect as hitching to the upper link or the axle which makes tipping over backwards very easy.
The 8N I had didn't have a strong enough hydraulic to lift the front end by lifting with the three point alone. I've other tractors that will get the front end very light with load on the three point. Often to the point of requiring steering with the brakes not the front tires.
Stump pulling with a wheel tractor is not a safe operation when pulling from the back. It might be safer to hitch the chain to the drawbar and run it under the tractor and to pull in reverse, but even then to never jerk on the chain.
Gerald J.
hillbillyOH
09-16-2007 07:43:56
He was using the 3-point.
If the tractor was going forward, and the 3-point was lifting, I could where that would put you on your back pretty quickly.
Lanse
09-16-2007 06:32:59
Heard it on the radio from the tractor..... That happened near here. Lucky dude!!
alan bane
09-16-2007 06:12:50
Saw it on the news, lucky man!
