Tractor Talk Discussion Forum
i think everyone died on the farmall forum
bm3501466
09-13-2007 18:58:16
This is a timing question. I have a 460 farmall with a 301 gas. I have the 460 governor on it so it only runs about 2000 rpm wide open. The timing degrees are supposed to be set a 22 at 2640 rpm. What do I set it at when timing at 2000 rpm? Thanks for any help.
Owen Aaland
09-15-2007 07:26:30
 Re: i think everyone died on the farmall forum in reply to bm3501466, 09-13-2007 18:58:16
From what I was taught for figuring timing when using propane, you need to have the end of combustion at 10 degrees past top dead center.
Using 22 degrees at 2640 you have a fuel burn of 32 degrees of crankshaft rotation. Assuming the time required to burn the fuel remains the same, at 2000 RPM the total crankshaft rotation would be 24 degrees. Subtracting the 10 degrees after TDC for the end of burn, you would need to set the timing to 14 degrees before TDC.
dlplost
09-14-2007 10:38:01
They're all over on the redpower site..
ejr-IA.
09-14-2007 09:25:57
18 to 19degrees
sammy the RED
09-14-2007 05:59:31
bm3501466 said: i think everyone died on the farmall forum
Why do you say that ? third party image
whatintheworldiswrong
09-14-2007 09:10:33
 Re: i think everyone died on the farmall forum in reply to sammy the RED, 09-14-2007 05:59:31
no one knows the answer
