Tractor Talk Discussion Forum
Pressure relief valve wrench
chucktn
09-13-2007 13:48:51
I'm getting ready to change out my pressure relief valve and was wondering if anyone has a picture of the 11/16 wrench that you cut and weld with the 90 degrees? I'm wondering how far from the box end do you make your bend and how much of the handle you cut off.
dlplost
09-14-2007 10:43:27
 Re: Pressure relief valve wrench in reply to chucktn, 09-13-2007 13:48:51
drain the oil or put the front end in a ditch, or jack up the rear end to get the oil level below the pto shaft in the back, pull the 4 bolts, remove the pto shaft then reach in thru the side cover and remove with a regular wrench.
only takes a couple of minutes..
The only reason for the bent wrench is the pto shaft is in the way.
john-mi
09-13-2007 18:54:58
If you are working on a 8 or 9 n ford tractor go down to the 8N ford discussion section and ask there. Some one will chime in. John
