Hydrologic Fluid change
Sunspot
09-13-2007 13:06:39
I bought a used tractor with 1500 hours on it. I have no idea on what maintenance was kept on it. I already changed the motor oil, filter and hit all the grease fittings.
I would like to change out the hydraulic oil and filter next. The last time I bought fluid was at the local NAPA shop and it was $8.00 for 1 gallon. I will need 12 gallons for the change.
I do want to use a good long lasting fluid but should it cost $96.00? Any suggestions?
Sunspot
09-14-2007 05:08:58
 Re: Hydraulic Fluid change in reply to Ken Macfarlane, 09-13-2007 13:06:39
bva said: (quoted from post at 05:45:42 09/14/07)
First I would try to determine if the fluid had ever been changed and at what intervals it needs to be chaged.
The operators manual calls for a change every 600 hours. I�m not trying to get out on the cheap side but I was wondering what the usual price was paid for a good quality oil and where it was bought.
As it is a used tractor I would like to know that the servicing is up to date. I keep a log on what was done and when it was done. If I sell it in the future, I�ll pass on the records to the new owner.
135 Fan
09-13-2007 21:32:07
 Re: Hydrologic Fluid change in reply to Sunspot, 09-13-2007 13:06:39
The oil could be analyzed to see if it's still good to use. It could even be run through a filter but instead of buying the oil from a dealer you could just buy oil that meets the same specs. $96 may seem high but it will last a long time so the per hour price is very cheap. I know in my MF 135 the MF oil works the best. It's not too much more than non MF oil. Dave
msb
09-13-2007 20:32:25
 You been farmin long? in reply to Sunspot, 09-13-2007 13:06:39
Ain't nothin worth buyin cheap these days.
showcrop
09-13-2007 18:44:20
If it has a manual trans use plain hydraulic but if it has any sort of powershift use hytran.
old
09-13-2007 15:03:15
Buying in 1 Gal. jugs is the expenseive way to buy the stuff. Buy it in 5 gal. buckets and the cost will be about a 1/3 less if not more.
bva
09-13-2007 14:45:42
First I would try to determine if the fluid had ever been changed and at what intervals it needs to be chaged. I would visually inspect and smell the fludi to see if there were indications of problems. Then I would decide if the 96 dollars is small potatoes or too much to spend and then risk the welfare of my tractor. Personally I would check to now and again and change it around engine rebuild time.
Sunspot
09-13-2007 13:34:17
It's a '86 Ford 3910.
MSM
09-13-2007 13:27:55
What kind of tractor? Most now use a universal tractor fluid(UTF) NOT hydraulic oil.
Joe(TX)
09-13-2007 14:12:04
 Re: Hydrologic Fluid change in reply to MSM, 09-13-2007 13:27:55
The univeral tractor fluid is actually universal hydraulic fluid. It is just also used in gearboxes. It is still primarily hydraulic fluid.
