Tractor Talk Discussion Forum
Battery question - Dodge truck and diesel tractors
jdemaris
09-13-2007 08:00:39
I know I overthink things sometimes - but . . . I'm wondering if I'm missing something here.
I've got a first-generation Dodge truck with the Cummins diesel. It uses only one starting battery which is kind of unusual. All my Ford and GM diesels use two smaller batteries - as well as most of my diesel tractors.
It can get 30 below zero here - but it's unlikely I'd try to drive a diesel at that temp. Still, I want to have the option to start it at zero temps - even if I forget to plug in the heater. Battery capacity gets cut in half at zero. Dodge calls for a single battery in my truck that has a minimum of 1100 cold-cranking amps at zero temp and a reserve of 170 minutes. It is a BCI type 31 battery. I'm finding out that hardly anybody makes such a battery anymore. Most for sale now - the commercial 31s - are only 925 CCA. Deka still makes one that is rated 1100 but it costs $140 with only a 1 year warranty. As I said - I tend to think a bit too hard at times. But - if I buy the $140 battery - it only comes with a one year warranty - because it's commercial. On the other hand, I can buy two smaller batteries - like my Fords and GMs use - at around $60 each - and get a much longer warranty - and much more reserve capacity and cold-cranking amps. Is there something here that I am overlooking? I am wondering a bit if a larger single battery can be more long-lived than two small ones - regardless of warranty. I had an Exide type 31 in my IH tractor - bought it in Jan, 1999 and it just went bad last month. But - it was not started every day like a truck will be - not even close. I've also been told that some CCA claims are make-believe - but that was from an Interstate battery dealer. I see it like this. Battery weight is the all important factor. Any size battery can be custom tailored to put out more amps at a fast rate - but then sacrafice how long it can do it. I checked around at many lists of batterys - and weight seems to be the determing factor with all of them. In regard to the BCI type 31 battery my 92 Dodge W250 calls for - I found this.
Deka type 31 versions: 1231MF - 1125 CCA, weighs 61 lbs., 195 reserve capacity.
1131PMF - 925 CCA, weighs 56.5 lbs., 170 reserve capacity
931MF - 650 CCA, weighs 51 lbs., 145 reserve capacity
I found several type 31 brands for sale locally - all listed as commercial with one-year warrantys and all no more than 925 CCAs. So, I assume they are equivalent to the Deka battery that weighs 56.5 lbs.
If I put in two, type 27 batteries - it will be cheaper, the warranty is much longer, I'll have 94 lbs. of batteries, and 1500 cold-cranking amps.
Is there an advantage to using the single battery that I am not seeing? And, I guess this applies to tractors as well.
shinnery
09-14-2007 02:07:27
 Re: Battery question - Dodge truck and diesel tractors in reply to jdemaris, 09-13-2007 08:00:39
I just bought a 92 Dodge 250 Cummins 221K mi. and they said it needed a new battery when I went to pick it up so I went to my local Interstate Distributor and bought a Econopower Gr. 31 for $25 and change, six months warranty. Cranks it beautifully, I don't think it has ever turned over one full revolution before it started. When Interstate batteries get a year old, on display, or they warranty it and it is not bad, they sell them under the EconoPower name. Any size they have, if you have a trade-in, is $25 or so including Texas sales tax. They are all warrantied for six months. Run them in all my vehicles.
caterpillar guy
09-13-2007 21:43:45
If you don't spend a lot of time keeping the cable ends clean the advantage to more will ultimately be less. I buy the 31's for my pete and it uses 4 of them I buy the bigger CCA to give an edge when out in the cold I run from FL to the north and west in January MT,ID,WY the cables with the studs on top will take less maintenance than the post tops and easier to clean.I grease mine at installation and once a year after till replacement. Series just gives voltage parallel is amperage same size alternator will charge either way regardless of battery size the 27's won't give the life the 31's will.Every connection will cause resistence in the line also even clean.
620
09-13-2007 19:08:51
FW Indiana yesterday just bought two deckas battery for 90.00 a piece .1231 mf #
jdemaris
09-14-2007 06:17:52
 Re: Battery question - Dodge truck and diesel tractors in reply to 620, 09-13-2007 19:08:51
Yes, the Deka 1231 is the one I wanted - and the only one I can find with the correct amperage. But, they want $140 for it here - not $90. For $90, I would of quickly bought it.
Davis In SC
09-13-2007 17:13:23
It has been a few years, but I have a Trojan Battery in my 92 Dodge, I am pretty sure it is over 1100 amps. IIRC, I paid about 90 dollars.
Bus Driver
09-13-2007 15:56:44
My Diesel tractor, new in 1978, used two 6 volt batteries in series. I think they were size 3EH. Typically would be strong enough to crank the tractor for 4 years. Then the battery guy showed me that one 12 volt battery he had was rated more CCA than the 3EH. So I bought it and used wood to fill out the battery box. It has worked well. My tractor and records are not nearby, so I have no dates nor battery size available now.
MSM
09-13-2007 13:38:27
I just changed the battery in my 93 Dodge cummins.Got a new one at Battery Warehouse for $112..1125 cca,same as the old one I took out which was 5 years old.The truck started last winter in Minot N.D.not plugged in at -35 no problem,let the grid heaters cycle once,spun over twice and started,truck has 285,000 miles on it.
mark
09-13-2007 10:58:14
See if you can find a Yuasa battery dealer. I had one that came in a 1980 JD 1050 and it lasted 17 (seventeen) years! That tractor was just a 37 horse 3 cylinder diesel...but that battery was huge. I tried to find a new one, but no joy. maybe all are not that good...but it sold me.
jdemaris
09-13-2007 13:09:26
 Re: Battery question - Dodge truck and diesel tractors in reply to mark, 09-13-2007 10:58:14
Yeah, I remember. We sold those John Deere-green Yanmar tractors new when they first came out in the late 70s. I think the 850 was the first - and it too came with a huge battery.
Trkr
09-13-2007 10:41:36
FWIW Ihave a 93 Dodge w-350 with the Cummins I bought new.The original battery went 5 years.I replaced it with a 925 battery and it is still in there.I have never had a battery last this long in anything.I have never had any issues starting,just keep the fuel doped in the winter.
John T
09-13-2007 09:50:06
Great question for discussion.
A lead acid battery is an electrochemical energy storage device and "generally" speaking since they use lead n acid to do so, the more lead n acid which also amounts to the more size n weight can store more energy. One advantage of two batteries in paralell is that the available cranking amps and amp/hr ratings is additive, where two in series that isnt true (only the voltages add). HOWEVER, batteries may be more prone to feed n cannibalize off each other in paralell versus them being in series.
Regardless if in series or paralell you wanna use matched batteries to lessen one feeding off the other in my opinion
In the old days they sold batteries rated in Amp/Hrs which gives a good indication of their energy storage capacity while nowadays its more CCA.
For good diesel starting fast cranking to help raise the cylinder temperature and avoid compression leak off is important so those initial CCA'a are needed. Another battery may actually be able to store more energy and could provide more amp/hrs to crank the engine longer but nottttt ttt have the high initial CCA to crank it faster. Looks like for a gas engine the longer crank time may be more important but in a diesel its that initial good fast crank over thats needed (even if not as long) i.e. a high CCA rated battery.
I also used to buy those 1050 to 1000 CCA batteries but havent seen them around as much lately?????
best wishes
John T
jdemaris
09-13-2007 12:49:31
 Re: Battery question - Dodge truck and diesel tractors in reply to John T, 09-13-2007 09:50:06
Most of the companies still post the long-term draw specs - but if it's for stuff with wheels or tracks - you've got to search for it. If you are buying batteries for solar-electic - they always list the amp-hour ratings because that's about all that counts (for solar application).
For the type 31 batteries - the long-term draw specs are given in "reserve capacity" instead of "amp hours" - both are valid. The "reserve capacity" is the time the battery can deliver 25 amps and maintain a minimum terminal voltage of 10.5 volts at 80� F.
A amp-hour rating is a little more ambiguous and is based on one amp draw per hour - but the amp hour ratings used for batteries have to be accompanied by an extra number or they don't mean much.
One example is a Deka 900 cold-cranking-amp battery. It has a reserve capacity of 180 and a 20 Amp Hour rating of 95, a 10 Amp Hour rating of 80, and a 1 Amp Hour rating of 50.
The battery Dodge calls for OEM for the first-gen. Cummins diesel has a reserve capacity of 170 minutes - so I suspect around a 20 Amphour rating of around 90.
I think I'm going to put in two group 27 automotive batteries. At least they come with a long warranty. Walmart has them for $69 each - 750 CCA and 180 reserve capacity. So, for $138, plus $20 in extra cables - I get 1500 CCA and 360 minutes reserve capacity. Seems to make sense.
I realize, that in most cases - not that much battery is needed. But, when the rare case comes up - it's nice to have the extra cranking power.
John T
09-13-2007 09:49:37
best wishes
John T
Haywood
09-13-2007 09:15:42
Running 2 group 27 would be fine with Double ought cable for Jumpers.
Also I would recommend getting a stud type or combo post top if they are available and use the tall led nuts to hold the cables. They are so much easier to service vs the standard post.
Always buy the batteries in matched pairs.
or like for like.
Tramway Guy
09-13-2007 09:04:32
I had a '93 Dodge with a single battery that started fine down to -25F. But I also ran a 5W-30 oil in the crankcase (bought from a local tractor dealer). If it got colder that that, I tried to plug in the block heater, which is standard on the diesel.
You had better have winterized fuel, because most of the problems I have ever had with any of my Cummins Dodges have been to fuel gelling...and not with starting, thanks to the manifold heater and the direct injection engine.
Mike M
09-13-2007 08:29:21
FWIW ? When I used to work at the Navistar truck dealer we had a Crown battery guy for our batteries. He recommended NOT to sell the largest CCA one they sold and sold us the next size down.This was because he said they didn't seem to hold up as good because they make the plates thinner to get more in to up the CCA or something like that.
Also his batteries would usually test over the CCA rating, which was a good thing.
jdemaris
09-13-2007 08:39:17
 Re: Battery question - Dodge truck and diesel tractors in reply to Mike M, 09-13-2007 08:29:21
I've been told - or read - the same thing. A same-sized battery can be custom tailored to - put out high cranking amps with low reserve - or - vice versa. But, I think the latter uses heavier plates and can last longer.
I've been wondering if one large battery might have thicker plates that two smaller ones because all is one case - so less space is wasted.
What the heck if "FWIW?"
Brokenwrench
09-13-2007 08:19:52
I have a 91 dodge deisel in the shop right now (transmission work). The guy has two batteries hooked up in parallel. Works fine. What I don"t know is if you go in parallel with two 750 CCA batteries that you will actually double your CCA, maybe you will. The other thing to consider, is it gonna put more load on your alternator to charge and maintain two batteries??
Hopefully someone with a better grasp will chime in. Good luck BW
jdemaris
09-13-2007 08:33:18
 Re: Battery question - Dodge truck and diesel tractors in reply to Brokenwrench, 09-13-2007 08:19:52
Parallel hookup doubles the CCA. As far as load on the alternator - I cannot see where it can possibly be a problem. It's going to put back into the batteries whatever you use - and that's it. Once a battery is fully charged, it takes next to nothing to maintain it. I've got a Chevy Blazer diesel with a motorhome body on it - and in all it has four batteries and a smaller alternator than my Dodge has. Two starting batteries and two deep-cycle batteries - all charged by the one Delco 10SI alternator.
Are the two batteries installed sideways in your Dodge? I checked on mine, and it looks as though two put in sideways and hooked in parallel - will just fit.
Brokenwrench
09-13-2007 08:46:07
 Re: Battery question - Dodge truck and diesel tractors in reply to jdemaris, 09-13-2007 08:33:18
Thanks for clarifying JD, I didn`t really think it would matter, just didn`t want to offer that as fact. I`m not great with a computer but I believe FWIW means---For What It`s Worth...
Mike M
09-13-2007 10:04:36
 Re: Battery question - Dodge truck and diesel tractors in reply to Brokenwrench, 09-13-2007 08:46:07
Yes, that's what I meant --for what it's worth---
not,F'in W-ild I-n W-oods LOL
