Tractor Talk Discussion Forum
Farmall 460 Engine Modifications
W. D. Burgess
09-10-2007 11:11:29
Does anyone know if the 221 cubic inch 460 Farmall engine can be made a 301? It seems that you could remove the sleeves and bore the cylinders for the 301 pistons.Has anyone ever done this before?
ejr-IA.
09-10-2007 13:32:58
 Re: Farmall 460 Engine Modifications in reply to W. D. Burgess, 09-10-2007 11:11:29
You will need a crank and rods from a 560 and 301 pistons.You didn't say gas or diesel just pull the sleeves and hone for stock bore 301 pistons or bore for over sized 301 pistons.Will need some type of ring to fill the top flange area.
W. D. Burgess
09-11-2007 06:39:32
 Re: Farmall 460 Engine Modifications in reply to ejr-IA., 09-10-2007 13:32:58
Thanks a lot ejr-IA. This is the exact information I was looking for! Thanks again for your help.
Bill in Va.
