Tractor Talk Discussion Forum
Oil Filter Location
Logan B.
09-08-2007 15:04:07
My Dad has a John Deere 3010 on LP. He had a stroke about a year ago and I am trying to keep the little bit of land he has clean & plant feed for the cows. He says the oil & filter needs changing in the tractor, but can�t remember where the filter is. I�ve never done this before & was wondering if you could give me an idea of where the filter might be. I�m guessing it�s on the left side of tractor, close to where the plug is on the oil pan. There are four bolts holding a plate on & I�m guessing this is where the filter is. We got him to look at the tractor and he said yes that was it & then said no it wasn�t, that it was back above the rear axle. Any info you could give me would be greatly appreciated! If you possibly have a picture you could send me to locate the filter, that would be even better!
What type of oil & how much is needed for this oil change?
Thanks in advance!
Logan.
rrlund
09-08-2007 15:33:41
 Re: Oil Filter Location in reply to Logan B., 09-08-2007 15:04:07
If it's the same as the diesel,he was right the first time. It is in the side of the engine oil pan.
rrlund
09-08-2007 15:33:36
Logan B.
09-09-2007 06:16:52
 Re: Oil Filter Location in reply to rrlund, 09-08-2007 15:33:36
Thanks a bunch! I will give it a try one day this week after work.
Logan.
