MF 20C Industrial Tractor Z145 distributor
farmermech
09-08-2007 10:06:51
I bought a MF-20C industrial tractor in 1980. It's got appx 500 hrs on the tractor. What happened was the teeth were ground off of the gear on the distributor drive. It's got a Presto-Lite distributor in it and was wondering where a person can get parts for the distributor and what cause the gears to get worn off the distributor drive gear.
CENTAUR
09-08-2007 10:57:40
 Re: MF 20C Industrial Tractor Z145 distributor in reply to farmermech, 09-08-2007 10:06:51
PRESTOLITE is old name brought back after FORD got the AUTO-LITE name.AUTOLIE and PRESTOLITE are identical.Take the distributor to the dealer and they should have the BULLETIN ON that problem.and they may give you one and may offer to fix it.This has happened to various distributors and other gears over the years.I remember ford had a nylon speedo gear that took out the steel drive gear in the transmission in short order.The transmission man got to fix those. CENTAUR
farmermech
09-10-2007 13:53:38
 Re: MF 20C Industrial Tractor Z145 distributor in reply to CENTAUR, 09-08-2007 10:57:40
Do you mean a Ford automobile dealership? Any information is very helpful.
