Tractor Talk Discussion Forum
ring gear
javan
09-05-2007 19:39:36
Is there any tricks to putting on a new ring gear? I took the old one of ( IH cub) and found out it is hard to put on the new one
Clint Youse MO
09-06-2007 05:18:06
 Re: ring gear in reply to javan, 09-05-2007 19:39:36
either heat the ring gear or freeze the flywheel have had to do both at same time before to get one to slide on
big jt
09-06-2007 08:41:57
You can also just set it on the flywheel and heat it there. gear will heat much faster than the flywheel and eventually drop on. Have a hammer and driving punch handy to make sure it seats. just go around the gear with a torch, preferably a rosebud tip.
jt
Hobo,NC
09-06-2007 04:17:45
third party image
Money well spend to pay a PRO to do it, may be he will let ya watch.
Patrick Martin
09-05-2007 21:36:49
Be sure to clean the flywheel where it mounts as well.
Patrick Martin
09-05-2007 21:44:16
 Re: ring gear in reply to Patrick Martin, 09-05-2007 21:36:49
You might want to peen it in place too.
gene bender
09-05-2007 19:44:46
Use a torch to wasm it up and it will slip on easy. I fasten a pair of vice grips and then go around and around with the heat source till it will slip rite on.
banjo
09-05-2007 19:44:16
heat it up a little. if nothing else ,stick it in the oven for about 20 minutes at about 250*
Bob
09-05-2007 21:22:12
 Re: ring gear in reply to banjo, 09-05-2007 19:44:16
250 degrees ain't gonna do it. 450 degrees is more like it!
georgeky
09-06-2007 00:15:51
 Re: ring gear in reply to Bob, 09-05-2007 21:22:12
You tell'em Bob. Just like those crankshaft pulleys. 250 aint enough.
Hobo,NC
09-06-2007 04:19:21
 Re: ring gear in reply to georgeky, 09-06-2007 00:15:51
Maybe he likes his rare
