Tractor Talk Discussion Forum
Fordson Major E1A Problems Starting
SM5454Ford
09-05-2007 09:44:59
I'm having difficulty starting my 1950's Fordson Major E1A Diesel. It has a Simm's Injector pump and Simm's injectors. I have operated this tractor for many years with out problems. After normal operation I shut the tractor down and have not been able to get it started again. I have disassembles and cleaned every fuel component from the tank to each injector. I even went as far as to remove the valve cover and to remove each individual injector from the engine block and cleaned each very well. With a small shot of Starter Fluid I can get the tractor to run for a few seconds before it dies. An archived article mentioned "timing" and a component of or on the injector pump? Could this be my problem? I would appreciate any thoughts or suggestions anyone could make as I have completely no idea what to do at this point. Thanks.
frankiee
09-05-2007 13:27:21
 Re: Fordson Major E1A Problems Starting in reply to SM5454Ford, 09-05-2007 09:44:59
I just finished starting my dads Super Major 2 days ago.
We had to bleed the injector pump by opening the small bleed screw on top of the pump.
I am not sure what kind of pump it was.
I would figure you would have to bleed the injector pump for starters
RAB
09-05-2007 09:54:29
First question is: Is there air in the system? A good place to start if all filters have been changed, engine fires and runs, so not too much wrong with anything we hope....
Regards, RAB
SM5454Ford
09-05-2007 11:47:40
 Re: Fordson Major E1A Problems Starting in reply to RAB, 09-05-2007 09:54:29
I've cracked each metal line going to each injector ports separately then while cranking the engine I see fuel spaying out and I tighten the nut. Then I go to the next port and do the same thing. This is the procedure I've been using to bleed the air. Is there a different procedure I should use. Thanks for your help.
Regards: Scott
RAB
09-05-2007 12:42:01
 Re: Fordson Major E1A Problems Starting in reply to SM5454Ford, 09-05-2007 11:47:40
Yes, but does air come out as well, when you do this procedure? That is the important thing. If it does, and I suspect that is the case, either you have not cleared air from the system further back from the injector lines (pump and/or filter) or there is an air leak which needs tracking down and rectifying. That could be air drawn in by the lift pump (does it have one?) due to a restriction before it.
Regards, RAB
