Tractor Talk Discussion Forum
JD carb question on cross over numbers?
1936
09-05-2007 06:48:00
Can a dltx 53 be used in place of a dltx 71 which is now on a JD A 1949?
old
09-05-2007 08:27:12
 Re: JD carb question on cross over numbers? in reply to 1936, 09-05-2007 06:48:00
Any of the carbs made for the styled A will work on it but not from the unstyled. Found that out when I needed a carb for my unstyled B. So you have a choise of 4 cars the 53, 33, 71 and 72. As per my catalog
Mike M
09-05-2007 07:06:05
If that 53 is for an A then yes. Any A carb. will work on an A. The problems arise when you try to put one on from an engine sized alot different.Like if you put an A carb. on a B or a B carb. on an A that is where you start having problems. If you have the 2 different ones together you can see the differance in the amount of air they are made to flow as the B is much smaller in the venturi and throttle plate.
