Tractor Talk Discussion Forum
enough power???
youg gun
09-04-2007 20:00:23
any body out there tell me if i can pull a 3-14 plow with a wd allis???
ohio
09-05-2007 18:22:00
 Re: enough power??? in reply to youg gun, 09-04-2007 20:00:23
with loaded tires or wheel weights. unless you've got some serious clay.
Michael Soldan
09-05-2007 04:47:44
A WD Allis will haul three furrows..were a great tractor!
2t2@ia
09-04-2007 20:56:48
Well, it depends. First off, you would have a much better chance with a mounted plow. Second, what kind of soil do you have? Soil makes a lot of difference. Here in the Clarion Webster soil association of north central Iowa, there is not much plowing any more. When there was, plows pulled much easier in the spring. However, spring plowed land did not work up very easily. In the spring we pulled 2 14's with a 1939 John Deere B many years ago. Haven't plowed any in a couple of decades.
Glenn F.
09-04-2007 20:27:37
It'll pull it down the road.
Glenn F.
LenND
09-04-2007 20:25:57
We pulled a 3-14 Allis plow with a WD. We also pulled the same plow with a WC in 2nd gear. It worked a lot better with the WD.
youg gun
09-04-2007 20:09:39
about all ill do with it is plow a garden or two. should work for that. right??
Sid
09-04-2007 20:05:34
In some conditions yes.
