Tractor Talk Discussion Forum
Disassemble Hyd Cyl on Ford Backhoe--how??
Leaky Boot
08-29-2007 12:16:48
On front loader, lift cyl on 555D. How does the end come off. There are two notches in the end that comes out and a little 1/8 inch rod or wire sticking out the side of cylinder about an inch or two from end. Do you pull this out and unscrew it?? Thanks for any info. LB
JCSinGA
08-29-2007 12:23:50
 Re: Disassemble Hyd Cyl on Ford Backhoe--how?? in reply to Leaky Boot, 08-29-2007 12:16:48
If you will turn the end with the 2 notches it should force the wire out and if not the wire has to come out anyway, then carefully with a hammer and chisel the end will come out of the tube. The wire is what actually holds the gland in the tube.
Leaky Boot
08-29-2007 12:42:21
 Re: Disassemble Hyd Cyl on Ford Backhoe--how?? in reply to JCSinGA, 08-29-2007 12:23:50
No threads??? Just the wire out and it comes out?
Dave in Tx
08-29-2007 14:27:54
 Re: Disassemble Hyd Cyl on Ford Backhoe--how?? in reply to Leaky Boot, 08-29-2007 12:42:21
Yep, just take the wire out. Take the hoses off, grab the cylinder rod and jerk it out. May have to hit it a time or two if is rusted in at all.
