Tractor Talk Discussion Forum
1086 cab kit
Jim Johnson
08-29-2007 03:17:10
I'm still working on that glue on the headliner. It's made of fiberglass so I don't really want to try a wire wheel.
That gasket scraper wouldn't touch it but found some 3M General Purpose Adhesive Cleaner that works with some elbow grease.
What I was wondering now is just how clean it needs to be? All of it comes off real good except the very top, It Is Tough, they must have used a different glue there because it still has a blotchy dark yellow look to it but it's fairly smooth to the touch.
Thanks
Jim
HuskerMedic
08-29-2007 10:31:56
 Re: 1086 cab kit in reply to Jim Johnson, 08-29-2007 03:17:10
Just wondering-did you try heating it?
MH
08-29-2007 08:37:39
Jim,
Can't help with the question, but I would be interested in knowing who you got the kit from & what you think of its quality & fit. Thinking about redoing the cab in my 886 this winter.
Thanks,
Matthew
Jim Johnson
08-29-2007 15:33:37
 Re: 1086 cab kit in reply to MH, 08-29-2007 08:37:39
Got from Case IH and I don't have it in yet, hopfully this weekend, I'll let you know.
Jim
MH
08-30-2007 10:11:27
 Re: 1086 cab kit in reply to Jim Johnson, 08-29-2007 15:33:37
Thanks Jim, I would appreciate that.
Matthew
Allan In NE
08-29-2007 03:46:38
Mornin' Jim,
I wouldn't even waste my time.
That glue that they send with those kits grabs like you wouldn't believe.
Fact is, you'd better have it where you want it when applying the insulation because you can't move it, can't slide it, can't change it. Not one little bit.
If you've got the dirt and grime washed off of 'er, I'd plant it. No worries. :>)
Allan
Jim Johnson
08-29-2007 08:30:40
 Re: 1086 cab kit in reply to Allan In NE, 08-29-2007 03:46:38
That's what I'll do then, thanks Allan.
Jim
