Tractor Talk Discussion Forum
Statuionary engine throtle control
37 chief
08-26-2007 19:49:33
Any one know where I may find a stationary engine throtle control. I picture them as a knob you pull, and twist to lock the throtle to any engine speed. Thanks stan
Allan In NE
08-27-2007 05:28:43
 Re: Statuionary engine throtle control in reply to 37 chief, 08-26-2007 19:49:33
Stan,
Any irrigation outlet will have locking throttle control cables, Murphy switches and hour meters.
Also, hydraulic shops carry electric "idle bump" solenoid kits.
Allan
Janicholson
08-26-2007 22:12:59
Muncie Gear works.com JimN
dobber
08-26-2007 21:42:24
Plain twist lock type with T shaped chrome handle is what we have used for years on irrigation pump engines. Most parts places or HD truck parts places will have the ones with twist lock preset and fast shut down push button in center if you need that. Hydraulics use that kind a lot so hydraulic places will have those too.
Gerald J.
08-26-2007 20:56:30
 Re: Stationary engine throtle control in reply to 37 chief, 08-26-2007 19:49:33
You may want that control to be setting the spring tension on a governor.
Baum Hydraulics and McMaster-Carr both carry push pull and locking control cables.
You could simply use a shaft lock like used for electronics. A collet with a tapered outside and a nut with a tapered inside to squeeze down on the throttle rod.
You could use a set screw into the side of the bushing the throttle rod passes through.
You could put the throttle rod into a three bushing bind so friction holds it. Or a two bushing with spring pulling to the side bind for friction loading.
You could put a rotary motion piece in the linkage and arrange a fixed disk with some friction lining between it and the rotating disk. That friction lining could be a part for a MF-135. Spring load those plates pushing against the friction lining.
You could neglect to lubricate the bourdon cable and put extra bends it to create more friction.
Gerald J.
DCM
08-26-2007 20:26:09
My JD-model E had a loose throttle that would jump around in time with the oscillations of the engine running,when I looked at one at our club, there is a spring around the throttle shaft that puts tension on the throttle keeping it in a set position. Dan
Walt Davies
08-26-2007 20:20:33
I would check with your local parts house they should be able to fix you up with something that works.
Walt
Coloken
08-26-2007 19:54:35
Air plane junk yard.
