OT GearVendors underdrive/overdrive
Gary in Mozarks
08-26-2007 07:03:17
I was reading the post about ford rear end ratios and it brought to mind a topic which I have been looking into. Gearvendors overdrive units. Used in fleetwood motor homes and some corvettes and trucks, right from the factory. Bolts to the end of the tranny and converts a 3 speed into a 6 speed with OD. Warrentied reguardless of horsepower. Pretty sharp unit, including the price. Has anyone had experience with these things? Id like to hear about it.
69Chev
08-26-2007 20:18:20
 Re: OT GearVendors underdrive/overdrive in reply to Gary in Mozarks, 08-26-2007 07:03:17
I have a 69 Chevy 1 ton with a 427, TH400 and 4.10 gears. It also has a Doug Nash OD (.82) resulting in six speed capabilities and a final gear ratio of 3.36. I pull a 28 ft. enclosed trailer, sometimes at scarey speeds that I should not be proud of. Everything works great.
Spook
08-26-2007 16:21:41
Not the same idea, but I would like to see a overdrive unit for small cars, I get 30mpg in my HHR, I really like to see 40+, since I drive 100+ miles per day.
L.C.Gray
08-26-2007 15:49:56
I had one on my '86 F-350 4x4 Crew Cab. It had a 6.9 and a 3 sp auto and 4.10:1 gearing. The GVO helped immensely across the board in pulling power, highway cruise speed and fuel economy.
It wasn't cheap, I think it was $2600 installed. If I remember right it was a .87 OD and effectively turned the 4.10 to a 3.20 and I saw an 18% rise in fuel economy.
If I had it to do over again I think I would go with the Liberty OD box. It was set up to go between the transmission and transfer case to be able to use all the gears in both 2x4 and 4x4 modes. It would be more expensive requiring more mods but I think it would be more versitile.
Big Hunter
08-26-2007 11:28:43
I thought about one for my chevelle, but the little bit I drive it and the cost turned me away
Gerald J.
08-26-2007 10:01:11
If there is any fuel savings it will take lots of miles to pay for one.
On my '98 F-150 with manual transmission, the factory 3.08 gears left it lifeless and limited to 2200 pounds trailer towing. I considered such an underdrive, but its price was too high. I paid a local hot rod shop to put in 4.10 gears in the drive axle that increase the GCWR from 6500 to 9900 pounds and I rate the truck at 4700 pounds trailer towing rating now. I've loaded it to 6000 pounds in a wagon of beans and had no problems hauling that to the elevator and up the slopes to the scale and leg.
The engine is a 4.6 L V-8 and with its HP peak at 4700 RPM the factory gearing in overdrive put it down around 2200 RPM like a diesel and it hasn't guts at low speed. Its a high speed engine.
And though I was prepared to accept a loss of gas mileage it averaged 16 mpg unloaded before and still gets 16 mpg after unless I run it in the low 80 mph for hundreds of miles. Last weekend I did 390 miles with a 3000 trailer on its tail on 25 gallons of gas.
Yup I'll probably wear the engine out faster by running it faster but it sure does have great throttle response and gets off a line well.
Gerald J.
Chances R
08-26-2007 09:20:42
I thought about them for my 99 ford f450 but after I wondered who would be able to fix it if it broke down on a highway I decided not to mess with it.
Roy Suomi
08-26-2007 08:30:55
I got a Spicer Auxiliary box for my Ford F-600 with a .86 overdrive..Now I've got 15 forward speeds and 3 reverse..Oh , If I only had more ponies under the hood [ 330 c.i. ], I wouldnt be so busy shifting on hills...
suptscottyb
08-26-2007 07:13:43
No experience but, I looked into them and talked to a few guys that ran them in their pickups. All reviews were good. The price kept me from putting one into my old 12 valve dodge.
