Tractor Talk Discussion Forum
OT, Dodge Hemi not running right
MF Poor
08-25-2007 17:18:17
Off topic but there's a lot of knowledge on here.
I've got an '04 Dodge 2500, 4X4, Automatic with 5.7 Hemi. 75,000 miles. It was running fine, then as we were going along about 60 mph, it got a vibration. That ended up being a bad engine miss. It won't idle, and dies unless I keep rpms up above 1000. Hard to safely stop (power brakes/power steering)
No shops open in our town after noon. Stopped in an Advance Auto and had them hook up their diagnostic computer here's the codes I got.
DTC (Codes)
P0300
Random/Multiple Cylinder Misfire Detected
P0301
Cylinder 1 Misfire Detected
P0113
IAT Sensor ! Misfire Detected
P0340
Camshaft Position Sensor A - Bank 1 Curcuit Malfunction
P0335
Crankshaft Position Sensor A Circuit Malfunction
DTC Pending (codes)
P0300 Random/Multiple Cylinder Misfire Detected
P0301
*These codes indicate a malfunction in certain systems or components. Proper diagnosis should be performed by a mechanic or through prper diagnostics outlined in the service manual for your vehicle*
Any clues?
A friend who was a dealer mechanic at a Ddge dealership (albiet transmissions) suggested, and I changed all 8 coil packs and all 16 spark plugs. (yes, 2 per cylinder) No change in how it runs or the codes.
TIA
MF Poor
08-27-2007 05:05:52
 Re: OT, Dodge Hemi not running right in reply to MF Poor, 08-25-2007 17:18:17
Follow-up;
Valve cover is off. #1 intake valve spring broke. Did NOT hit piston! Valves sealed when cylinder aired up. Holds compression. Valve spring is $11.00. Labor is $260. Entire bill should stay under $300. Will be ready by 5PM. Work will be done bt A.S.E. mechanic, former Dodge dealership tech, warranty on work.
Back on the road again.
MF Poor
08-27-2007 07:11:47
 Re: OT, Dodge Hemi not running right in reply to MF Poor, 08-27-2007 05:05:52
The news just keeps getting better. Truck is done. It went a lot quicker than expected. Total bill will be $254.40.
MSM
08-25-2007 23:14:15
You have a broken valve spring on the #1 cylinder. Common problem on the Hemi"s.
MF Poor
08-26-2007 12:29:18
 Re: OT, Dodge Hemi not running right in reply to MSM, 08-25-2007 23:14:15
You're absolutely right about the #1 cylinder breaking a valve spring. Didn't drop. I'm HOPING it seals with a new spring. Truck is an '04 built in late '03. Hemi valve springs broke like eggs in '03 production run motors. Dodge claims that's past history. 7 year/70,000 mile warranty. Springs break on average @ 75,000 miles. Mine has 74,800.
Spring is $10. Labor to replace along with gaskets/ect, $450. If valve doesn't seal and head comes off, numbers grow substancially.
MN Scott
08-25-2007 19:46:15
Bad Crankshaft Position Sensor? Have a experanced mechanic diagnose the problem. Much cheaper than throwing new parts at it.
Leland
08-26-2007 10:01:37
 Re: OT, Dodge Hemi not running right in reply to MN Scott, 08-25-2007 19:46:15
according to the book you should change all 16 plugs in a hemi every 30,000 miles good news they are about 16.00 a piece
MF Poor
08-26-2007 12:24:38
 Re: OT, Dodge Hemi not running right in reply to Leland, 08-26-2007 10:01:37
Plugs came out yesterday @ 74,800 miles and looked like new. Dealer mechanic says Hemi plugs go 80,000 to 90,000 in work trucks, over 100,000 in play trucks. I replaced them with Bosch Platinum.(Their top of the line plugs) $7.95 each
Leland
08-26-2007 20:37:38
 Re: OT, Dodge Hemi not running right in reply to MF Poor, 08-26-2007 12:24:38
actually the correct plugs for a hemi are not platinum they are made out of a much more costly and harder metal that has a name I can't even to pronouce
MF Poor
08-27-2007 03:33:47
 Re: OT, Dodge Hemi not running right in reply to Leland, 08-26-2007 20:37:38
Well, you better tell Dodge, Champion, Denso, NGK, Bosch, and anyone else who'll listen to you. They ALL spec the same plugs, and the Bosch Platinum are THE MOST EXPENSIVE, and all are fairly common plugs. Someone gave you some bad information
Leland
08-27-2007 05:10:26
 Re: OT, Dodge Hemi not running right in reply to MF Poor, 08-27-2007 03:33:47
There is a local mechanic that has a show every saturday on a local station and he was just talking about hemi plugs this past weekend , and he came up with some wild name for the plugs a hemi takes . Send him an email at
askthemechanicspringfield.com
this guy is pretty sharp and he now does most all of my more troublesome repairs .
MF Poor
08-27-2007 06:30:48
 Re: OT, Dodge Hemi not running right in reply to Leland, 08-27-2007 05:10:26
I'm in a Hemi truck/SUV owners club with 6500 members nationwide. I've got all sorts of info through them, as well as through a mechanic that's changing the valve spring for me. I was told not to even spend the "big bucks" on the Bosch Platinum. It seems the best performance is from the OEM Champions. They last longer, run better, and get better fuel milage. They're less than $6.00 each.
You'll here all sorts of techno-wonders from everyone, but the best info comes from people who actually run Hemi's. A great many of the club members race, or at the very least, spend hours and cubic dollars chasing hp. Almost to a person, they say "cheap" Champions are the way to go. (This from a "Champion plug hater")
Leland
08-27-2007 07:30:23
 Re: OT, Dodge Hemi not running right in reply to MF Poor, 08-27-2007 06:30:48
probley true but I am just going by the info dodge has in there manuals about the servicing of hemis .
