Tractor Talk Discussion Forum
Piston Replacement
fatbob50
08-24-2007 20:01:17
I have a John Deere M and am replacing the pistons, among other things. I am wondering if anyone knows of a tool that helps to install rings on the piston. I would appreciate any and all related info on this. Also, my new pistons have no markings which indicate front or back. Does it matter which they go? Has anyone had any experience with these before? Thanks for the help. Bob
buickanddeere
08-25-2007 05:29:20
 Re: Piston Replacement in reply to fatbob50, 08-24-2007 20:01:17
What piston to wall clearance are you planning to use? What piston ring composition and end gap? Do you have a medium to heavy load to break the engine in with? The distributer bushing should replaced while the engine is apart. The cam & followers should be resurfaced. Wear which can cause uneven operation. Can't even be seen just eye balling the cam. May as well mill the deck and head surfaces to gain some compression. Those M's were so low they could almost burn Coleman lantern fuel
RobMD
08-24-2007 20:47:33
OH yeah, they'll have that piston ring tool at NAPA or any other ruputable parts store.
Your pistons should have come with directions- i'm quite sure that there is a way they have to go in... contact your supplier.
fatbob50
08-24-2007 21:44:03
 Re: Piston Replacement in reply to RobMD, 08-24-2007 20:47:33
Thanks, Rob,for the info and for your response. I will look for that tool tomorrow. Also, the folks I got the pistons from are good folks and I will contact them for info on the pistons. Have a good day, Bob
