Tractor Talk Discussion Forum
Checking water temp. gauge
John Deere Trac
08-24-2007 12:59:16
I'm not getting any movement on the water temperature gauge on my JD 2240. Is there a way of checking the gauge? Or is the gauge and water temp. sensor one complete unit?
dobber
08-25-2007 11:29:23
 Re: Checking water temp. gauge in reply to John Deere Tractor Rookie, 08-24-2007 12:59:16
You can view the JD parts catalog for your tractor anytime online. You'll have to register with a local dealer and sign in though to price parts online.
gene bender
08-24-2007 17:20:32
Very simple just take temp reading with the radiator cap off. This will tell you the temp of the coolant.
Gerald J.
08-24-2007 13:51:34
If there's an insulated copper wire from the gauge to the sender and an insulated copper wire (for other than a light) to the gauge for power then its elecctrical and two pieces. If there's a capillary tube from the gauge to the sender location, its one piece. Either can be checked with a cup of boiling water. You will have to add a ground wire to the sender of the electrical gauge after removing it from the engine.
Gerald J.
Lanse
08-24-2007 13:40:37
This might help
