Tractor Talk Discussion Forum
massey harris 44 electrical
Kent W ND
08-23-2007 08:56:11
I have a 51 MH 44 gas powered. Is it positive or negative ground. It is missing the battery cables so I can"t tell by post sizes. I don"t want to fry anything.
Thanks
toolman
08-23-2007 20:41:39
 Re: massey harris 44 electrical in reply to Kent W ND, 08-23-2007 08:56:11
I have one and it is positive ground, .
John T
08-23-2007 14:14:10
I dont know what ground it was original (over the years long ago I owned 7 of those but plum forget , but after you reconnect the battery AND BEFORE you start her Id turn on the lights (if it has any) or an ignition switch (dont start it remember) and see if the ammeter swings over to - discharge as it should ifffff ffff its wired to match the polarity of the battery.... Then BEFORE you start it Polarize the genny to be safe cuz if its started and the genny is polarized opposite from the battery it might harm the Voltage Regulator. The genny can be made to charge at either polarity once polarized so if you get the ammeter wired right so its not reading bass ackwards and the VR is compatible with your ground (many are bi polar) you may be fine. The coil should also be wired correct polarity to match your ground.
If you hook it up say Positive ground and that makes the ammeter work the right direction and the coils lil + terminal is wired to the distributor,,,,, ,theres a good chance thats the correct polarity but still polarize the genny before you start it to be safe.
John T
old
08-23-2007 10:33:08
Well if its 6 volts and has a genny then it will most likely be + ground. Now if its 12 volts and has an alternator then it will most likely be - ground. When it was new it was + ground
