Lubing a tach cable
Dairy Farmer in
08-20-2007 19:42:46
i was told to lube the upper part of the tach cable that i'm putting in a tractor right now but don't know how. Should i jut take some good spray lube and spray it inside the cable or what? first tach cable i have put in and am puzzled.
thanks in advance
DF in WI
shannon from ohio
08-22-2007 17:08:17
 Re: Lubing a tach cable in reply to Dairy Farmer in WI, 08-20-2007 19:42:46
(Justice Brothers Chain Lube).. "All other chain and cable lubes are JUNK!!"
Dan Hill
08-22-2007 04:26:48
The tachometer has a bushing in the drive end that never gets oiled.When my cable got noisy it wasnt the cables fault.I took the meter out and put one drop of Military LSA gun oil on the bushing and the noise and needle jumping stopped.Ive had car speedometers that were stuck tight, that broke the cable if the car was moved after sitting idle for a long time.
soundguy
08-21-2007 11:18:17
I also use graphite lubes.. though AFAIK.. they actually make speed/tach lubes specifically for this application..e tc..
Soundguy
rrlund
08-21-2007 06:44:29
I had trouble with the pin that runs the cable on my 1850 Oliver breaking because the cable was turning too hard in cold weather. I poured a little automatic transmission fluid down in to it. Problem solved.
Mike M
08-21-2007 06:05:50
Right or wrong ? I have did several with neverseze. I just brush it on as I feed the cable in. Just enough to cover the cable good.
Don-Wi
08-21-2007 00:20:54
Almost everytime I have to work on a tach cable it's ussually full of engine oil- so I'd say dump a little oil down it and call it good. Eventually oil will get past the drive and lube the shaft that way.
Donovan from Wisconsin
Bob
08-20-2007 19:55:06
A REAL autoparts store will have speedo cable lube.
RustyFarmall
08-21-2007 05:22:56
 Re: Lubing a tach cable in reply to Bob, 08-20-2007 19:55:06
Speedometer cable lube or regular grease gun grease. Put a gob of it in the palm of your hand, and then drag the cable through it as you feed it into the cable housing. Don't be stingy with the lube.
ldj
08-21-2007 06:14:08
 Re: Lubing a tach cable in reply to RustyFarmall, 08-21-2007 05:22:56
I use graphite.
