Tractor Talk Discussion Forum
Farmall H stuck between gears
Kevin 1976
08-20-2007 07:24:39
I got done useing the tractor everything worked, parked it. Went to use it again and it is like it is stuck between gears. It wont go into neutreul, and when I let the clutch out it kills the motor. Can anybody tell how to get it unstuck. Thank you
Gary in Mozarks
08-20-2007 09:25:47
 Re: Farmall H stuck between gears in reply to Kevin 1976, 08-20-2007 07:24:39
Shovelman is right on, I have had to do that to two of our tractors. a 424 and a 460. A little weld on the end and then ground down and she works like new again
Shovelman
08-20-2007 07:33:10
Remove the shift lever and realign the shift rails with a big screwdriver.
The pivot pin that holds the shift lever in place is retained with 2 disc type expansion plugs, which I beleive are 5/8".
Many times the end of the shift lever is worn, allowing it to slip between the rails, causing the problem. We build them up with a little weld if needed.
Good luck,
Scott
