Tractor Talk Discussion Forum
Fuel tank has a hole
37 chief
08-19-2007 12:50:18
The fuel tank on my chipper has a rustrd out spot. Is fiber glass cloth a good sealer, If I put a couple coats on the bad spot? Stan
doogdoog
08-19-2007 21:10:32
 Re: Fuel tank has a hole in reply to 37 chief, 08-19-2007 12:50:18
Aloha, Fiberglass resin isn"t a good patch anymore if you use any type of ethanol gas. We had a lot of problems with ethanol gas in fiberglass tanks and it produced some gummy stuff that ruined a lot of small boat engines. If the tank has a rusted spot, check out the rest of the tank because you may have more holes starting (in that case, get another tank). You could do as the other poster said (screw in pan head sheet metal screw with gasket) and then cover the patch with a fiberglass cloth, JB weld, LPS Strong steel stick, etc. Just be sure to apply to a clean dry surface.
Mahalo,
doogdoog
HENRY E NC
08-19-2007 14:54:16
It usually works for me. There is a patch especially made for gasoline. (NAPA) Also, I believe that JB Weld applied with some glass material will do OK. I have used a product called Marine-Tex similar to JB Weld to repair gaas tanks in boats and small machinery(currently have a weed whacker with patched gas tank for last 6 years done with Marine-Tex which you can get at any boat store.
bill mar
08-19-2007 14:29:02
napa used to sell a fiberglass/resin type patch kit just for gas tanks.
Janicholson
08-19-2007 13:37:26
no. it is affected by the fuel. If it is just a pinhole, a course sheet metal pan head screw with a neoprene oring or gasket will stop it quick. If an area is thin, the best is to clean it dry it and solder over the area with acid core solder then clean again. Use a large electric iron, not a torch unless it has been boiled out to rid it of trapped fumes and vapors. JimN
GeneMO
08-19-2007 14:33:07
 Re: Fuel tank has a hole in reply to Janicholson, 08-19-2007 13:37:26
I was fortunate enough to find several large copper soldering irons at flea markets or antique shops over the years. One of the perks of traveling three or four states. I try to visit the junkiest ones. best deals there. These soldering irons let you transfer the heat to a fuel tank without having an open flame.
Gene
