Tractor Talk Discussion Forum
OT Dodge Dakota Oil Pressure
super99
08-19-2007 04:11:14
A 97 Dakota with a 6 cyl, 5 speed. When you are driving and slow down to make a sharp turn, or stop at a light, the oil pressure drops to 0 and the bell goes off. Soon as you give it a little gas, it comes back up. Carries 40 # cold and about 25# warmed up. Asked a local mechanic about it and he said it's probably the sending unit, that he has a newer Ram and it does the same thing. I want to put a guage on it so I know for sure. Where is the sending unit located on the motor? I changed the oil yesterday and looked the lower side of motor over real good and didn't see anything. The top side is quite cluttered, but found one on back of intake manifold beneath the plug wires about 2 1/2 inches tall. Not sure if it's for oil or water. Didn't see anything else. If I find the sending unit and replace with a line to guage, will the bell ring all of the time because it's not hooked up? Wondered it I would have to put a T in the line and hook up both. Changed the oil and filter and added a bottle of Lucas oil treatment. Any help appreciated, Chris
Super Steve
08-19-2007 10:38:54
 Re: OT Dodge Dakota Oil Pressure in reply to super99, 08-19-2007 04:11:14
Thats funny u say that, a friend of mine bought the same truck about a month ago and it did the same thing. I have heard about the oil pressure sending unit dropping like that. My work truck is a dodge and its done it since it was 6 months old (its a 98). Well we were wrong, 4 days after he got it the motor blew out of it. Get it checked out REAL well. Good luck Steve
marlowe
08-19-2007 08:10:17
i would start by changing the oil preasure sending unit. how many miles are on it?
Ryan - WI
08-19-2007 05:30:05
MIne did that when it was a couple quarts low. When you changed your oil, how much did you get out of it?
super99
08-19-2007 06:58:56
 Re: OT Dodge Dakota Oil Pressure in reply to Ryan - WI, 08-19-2007 05:30:05
It was full, I check it regularly and it does it reguardless if full or down a little. Chris
