Tractor Talk Discussion Forum
Part for 1966 JD400 backhoe
Ed65
08-18-2007 19:16:57
Thank you for taking your time to help. I am looking for a used hydrolic pump drive for a 1966 JD400 backhoe. The part number is T22915T. The dimensions are: 4 and 3/16 in. long. The center point of the two hoses on the front part of the drive measures 2 and 3/4 inches. My problem is that I bought an after market part, but the part is too long and there is not enough room between the pump face and the engine drive. The after maket part has the correct part #, but it is at least 1/4 inch longer that he original part. I have called everywhere that I know of and I cannot find a used one. All I can find is the after markert part that is too long. Since the backhoe is so old, I thought I could find one fairly easily. I can't shave the front or the back end down to make it fit because it will make the unit too thin at both points. The pump size is 3.01 cu. inches. I would greatly appreciate any info. on where I may find a used one. John Deere wants over $200 for the part and the after market is $85. Thanks for your time.
Ed
Dlm
08-19-2007 08:04:05
 Re: Part for 1966 JD400 backhoe in reply to Ed65, 08-18-2007 19:16:57
Change it over to a newer style coulping. It will cost a little more but will be a lot better.
Don
Bob
08-19-2007 00:36:24
How much do have invested in shipping for the WRONG part, and time wasted, piddling around?
If the genuine part DOES fit, it's a BARGAIN at $200.00, vs. an $85.00 part that DOESN'T fit, or a used part that's 1/2 or more worn out, itself!
