Tractor Talk Discussion Forum
Fordson Dexta gas model
Kim Nielsen
08-17-2007 17:02:46
What voltage system did these tractor run under, 12 or 6 volts, positive or negative ground.
What kind of cold cranking power should a person look for when buying a battery.
Thanks in advance
Kim
RickB
08-18-2007 16:51:49
 Re: Fordson Dexta gas model in reply to Kim Nielsen, 08-17-2007 17:02:46
That tractor operates on Lucas voltage which is both variable and intermittent. (just kidding, of course) Really can't help with a real answer. Electrical parts for your Dexta will be difficult to get, I can tell you that.
jimont
08-17-2007 17:54:45
Kim - We had a gas Dexta and it was a 12 volt system. Can't remember if it was positive or negative ground though. I believe if you google Oscar's Fordson site, you'll find the answer.
