Tractor Talk Discussion Forum
Cylinder liner search.
Mike M
08-15-2007 09:40:47
Looking for a cast cylinder liner to use in the makeing of a NEW rockshaft cyl. liner for my JD 720 D. ID is 4 1/4" length is 8 3/4" (or more) 5" OD minimum 5 3/16" OD is ideal.
Anyone got something laying around you can measure and also Know what it is out of. Thanks in advance if you can.
J Schwiebert
08-15-2007 18:27:44
 Re: Cylinder liner search. in reply to Mike M, 08-15-2007 09:40:47
Can you bore out the old sleeve and put a thin wall liner in it for a new wear surface?
Mike M
08-16-2007 07:46:10
 Re: Cylinder liner search. in reply to J Schwiebert, 08-15-2007 18:27:44
That may be an option ? But in the area at the bottom there is an o-ring groove cut and it may get really thin there.
Bob
08-15-2007 10:33:38
Have you tried LA Sleeve?
Janicholson
08-15-2007 16:23:14
 Re: Cylinder liner search. in reply to Bob, 08-15-2007 10:33:38
I second LA Sleeve, they are perfectionists and reasonable. JimN
