Tractor Talk Discussion Forum
HURCULES FLAT 6
WHISKEY BENT
08-10-2007 17:43:17
GOT AN OLD PORTABLE AIR COMPRESOR WITH A HURCULES FLAT HEAD 6 CYL. ENGINE. ITS STUCK BUT ONLY HAS 3200 HRS. HAS ALWAYS BEEN COVERED. DID THIS ENGINE EVER COME IN ANY TRACTORS? IS IT WORTH KEEPING OR SHOULD I JUST JUNK IT? CANT FIND A TAG ANY WHERE FOR INFO ON ENGINE, WHERE ARE NUMBERS? THANKS!
noncompos
08-11-2007 09:23:37
 Re: HURCULES FLAT 6 in reply to WHISKEY BENT, 08-10-2007 17:43:17
What's the name and model (capacity?) of the compressor?. May have a catalog listing (if it's on a trailer look on the frame and the sheet metal for a tag).
My 36-49 Motor Trk/Trctr manual shows 6 truck JX variants, but not the original JX; no tractor JX's, but tractor coverage is pathetic. Bearing catalog seems to show JX and "early" JXA thru JXD were poured bearings, but gives no dates; says inserted JXA thru JXG "late models" as 34-43. 1957 Motor has 8 JX's, but has no make-model listings. Even if can't ID engine variant, should check some welder or compressor forums before scrapping. Good luck.
J Schwiebert
08-11-2007 11:11:49
 Re: HURCULES FLAT 6 in reply to noncompos, 08-11-2007 09:23:37
Bud: I thought you were a Hercules man!. JX is the basic engine. After that you have from one to 4 more letters. Last one is the code for the bore size. The ones in between are if it had a stroke crank (letter L) and then CC for counterclockwise rotaion( boat motor)
noncompos
08-11-2007 13:01:00
 Re: HURCULES FLAT 6 in reply to J Schwiebert, 08-11-2007 11:11:49
John: No, almost all my very limited knowledge comes from vacuuming up info from real experts; in the days I was driving these things it was just hit the starter or pull the comp release, then hit the starter, keep the gauges and rpm's within range and if it sounded funny take it to the shop. What I worked on was mostly family, which in those days always needed work--kinda the not-so-good old days--everything else is just fascinating letters and numbers on the printed page. Take care. Bud
MF294-4
08-11-2007 05:29:06
Don't remember the enging # but the first JD 55 combines used a flat head 6 cyl Hurcules.
J Schwiebert
08-11-2007 11:13:12
 Re: HURCULES FLAT 6 in reply to MF294-4, 08-11-2007 05:29:06
Good think you called that to my attention!. I forgot, those are QX engines. They also have one head. Thanks.
sjh
08-10-2007 18:36:04
I know some parts are real hard to find and are expensive. If it has 2 heads it might be worth more in my opion. I would try to part it out before scrapping it.
J Schwiebert
08-10-2007 18:22:50
There are at least 4 basic models of hercules 6 cylinders. Does it have one cylinder head or two? Start there.
WHISKEY BENT
08-10-2007 18:48:52
 Re: HURCULES FLAT 6 in reply to J Schwiebert, 08-10-2007 18:22:50
HAS 1 HEAD. THANKS!
J Schwiebert
08-11-2007 11:14:38
 Re: HURCULES FLAT 6 in reply to WHISKEY BENT, 08-10-2007 18:48:52
Sorry, Read the above posts but the QX slipped my mind. How long is your engine and do you have any block casting numbers?
J Schwiebert
08-10-2007 19:10:39
It is a JX. Bore size will determine the last letter. Used a lot in military stuff.
